Yes - that's fine for MC cartridges...
But MM cartridges, by design, use the resonance boost, and EQ curves of the Inductance/Capacitance/Impedance circuit to adjust their frequency response...
This is why most of the very best (in terms of frequency response) cartridges, have been MM - the imperfections of the base F/R of the cantilever (and its resonances) was adjusted for by a basic EQ filter AKA loading.
MC cartridges have no such equivalent in their design - there is nothing in their base circuit design (including phono pre whether SUT or not) to provide EQ outside of the RIAA EQ.
So although most users are not aware of it, MM cartridges have a PEQ built into their design - and you can adjust its parameters by adjusting C & R (if you have a collection of cartridge bodies, you can sometimes even change the inductance, as same family cartridge bodies with interchangeable styli, were at different times made with differing inductances - designed to match differing styli!) - today with OEM styli impossible to find for many vintage MM's, this ability to re-adjust the EQ for the differing stylus becomes critical... (at least if you have as one of your objectives, an objectively neutral frequency response.... otherwise it becomes a completely subjective exercise of listening to different configurations with differing frequency responses for ones preference... you might as well be playing with a graphic equaliser, you would get much the same sonic experience!)
