That's pretty much what one would expect, the narrower horizontal with longer vertical contact patch, makes it more sensitive to VTF.Mounted the Hana ML on the Traveler - the ML sounds at least as good as the SL, which is what one would expect for so much more money. I’m getting more detail from the ML than from the SL, depending on where I set VTF. The ML is indeed even more setup sensitive than the SL in my opinion; 2.1 grams sounds different than 2.0 grams. But, it was not a night and day sonic difference between the carts initially.
I need to run the ML for at least 50 hours before I can really compare. It took a couple of weeks for the SL to fully settle in after I initially installed it, too.
Having said that, a Shibata vs a Microline should not be a night & day difference
