If chinese has done same progress in weapons this will be a big problem for americans and european . Not to say for Taiwan and Japan
What this really tells you is that in the field of electronics, China has moved worlds. SINAD is useful in detecting small objects - I'm talking about stealth and other things. With good SINAD, you can differentiate small enough objects from noise, and if China is coming out with the top level SINAD devices, then it's military should be on par or better than US / European counterparts in terms of radar, radar guided missiles, heat seeking missiles, basically anything that requires signal processing.
Remember, all of this stuff used to be the stuff of militaries. A dac with 120DB SINAD was used in submarines so the submarine people can hear enemy submarines back in the 60's. And now wave forms are used in analysis computers to detect enemy subs.
This is why audiophile industry should be science based, and less bullshit based because if indeed there is something that's truely better, then we are closing in on military grade radar equipment and sonar equipment.
Nothing tells the truth more than real measurements and real weapons.
The major problems of the 70's Sidewinders was that the SINAD wasn't high for its infrared detectors, so there's a LOT of noise, and there's a reason why flares were used, because flares look like noise back then (because the noise was so high) and could make the seeker head think there are 2 airplanes.
Nowadays, with super accurate detectors, the seeker head and differentiate between a flare and an aircraft.
