Hi
@staticV3
You're right. XIO includes two identical sets of 3x Uni-Q MX arrays to support both horizontal (table-mounted) and vertical (wall-mounted) orientations. When wall-mounted, the unit must be rotated so that the cables exit from the bottom.
In both configurations, the system provides the following discrete channels in a 5.1.2 configuration:
- 3 x Front-firing Uni-Q MX (L/C/R)
- 2 x top-firing Uni-Q MX (Lh/Rh)
- 2 x side-firing full-range drivers (Ls/Rs)
- 4 x P185 LF drivers (LFE)
The side-firing drivers are not Uni-Q MX units. This is intentional, as the Uni-Q’s wide dispersion would diminish the spatial precision required for surround effects in this application. Similarly, the centre top-firing Uni-Q MX is not used as a discrete height channel. Instead, it exists to maintain acoustic symmetry and allow flexible product orientation to suit both horizontal and vertical installations.
Inside XIO, a built-in sensor detects the unit's orientation. When a change is detected, the MCU automatically reallocates channels and adjusts crossover parameters to optimise sound performance for that configuration. Additionally, XIO features two internal microphones that measure the acoustic environment and generate custom EQ settings to mitigate excessive low-frequency boundary loading - something that’s common in typical use cases (e.g., wall or tabletop placement on reflective surfaces). We call this
Intelligent Placement Technology (IPT), and it can be initialised from the KEF Connect app. The IPT mics come with a HW mute switch, on the back of the product, for complete peace of mind.
We have also prepared something akin to a whitepaper for XIO, which I’ll be sharing shortly.
Hope this helps!
PS: The animations are for illustrative purposes only.
