Hi all,
I am looking to get into audiophile headphones and need a "reference" dac/amp or combo recommendation to audition a wide variety of headphones. I have no idea what my headphone sound preferences will be. I do know, I am not a particularly loud listener. In a home theater, volume usually peaks at 74db or so. No reference level nonsense for me.
In addition, I would like to keep this system for a good long time. I prefer a buy once philosophy with some future proofing.
Audio will be coming from a macbook pro (primarily)
Some of the headphones I would love to hear are HifiMan Sundara/Ananda, HD 660s (and maybe other HD models). I intentionally want to hear a high ohm resistance well liked model. But which headphones are for the next question. This one is focused on dac/amp. I just want to illustrate the ability to drive 25 ohm planar magnetic all the way to some 600 ohm dynamic models.
Budget is relatively flexible. Priority is to spend the minimum necessary to meet the functional value. So if e30/l30 can drive the full range, that is probably a great option (or dx3 pro).
Knowing what you know today, what would you have told your younger audiophile self to start with to save a bunch of money in the long term?
Thanks!
--Derrek
Thanks!
--Derrek
