Finally, you can calibrate your headphones to your ears.
This is definitely interesting and I appreciate all the discussion and explanation so far. Noob question here: I understand the need for open headphones to create a valid measurement with this mic. Does this also mean the resulting correction is only valid for those headphones, or could it also be adapted to closed back cans?
Specifically: I have a set of Focal Elex that might work for the measurement but I'd also want to correct my Audeze closed-backs.
Good question. Two separate things here.
First, the correction is specific to the headphone you measure. An Elex measurement corrects the Elex, it won't carry over to the Audeze, because each headphone has its own response at your ear. So you measure each pair you want to correct and get a correction for each.
Second, yes, you can measure the closed Audeze too. The "open headphones needed" idea is a simplification. The blocked measurement assumes free-air equivalent coupling (FEC), and no real headphone meets that perfectly. Møller et al. measured 14 headphones and found that all but one deviated from ideal FEC on the order of 2 to 4 dB above 2 kHz. It tends to be a bit larger for closed backs, but open vs closed doesn't reliably predict it. Hammershøi herself made this point, an open headphone isn't automatically FEC and a closed one isn't automatically bad.
The alternative, measuring in an open canal, trades that FEC error for the problem of holding the mic at exactly the same spot every time, which is difficult and prone to errors. So for a closed back you're picking between two imperfect methods, and the repeatable blocked measurement can be the better one. Neither is perfect, neither is wrong.
Short version: measure both, correct both, and the Audeze being closed rules it out.
Some do it manually and subjectively, using slow, targeted sweeps—through trial and error, and so on.
Great discussion here, many thanks to @Sean Olive, @solderdude, and of course @Marko_EarEqual for the enjoyable Saturday morning read.
Question for @Marko_EarEqual; do you think the issue of repeatability is one inherent to open canal microphones, or do you think there's a possibility that the magnitude of variation we've seen in the literature is partially down to how the open canal microphones people are using are designed?
I ask because there are plenty of blocked canal mic designs that can also have incredibly unreliable positional consistency, so I'm wondering if you've maybe seen (or done) any comparative evaluation of different open canal microphone designs similar to what Brinkmann et al. have done for blocked canal designs.
Thanks, and good question.
For an open canal measurement you want as little as possible perturbing the canal, so there is not that much room to "design" the sensor itself. The smallest electret capsules are around 3 mm diameter and 1.5 mm tall with two wires. A MEMS is similar in footprint. Probe tube approaches have smaller footprints but tend to be noisier.
But in my experience the dominant source of variability is fixation: keeping the mic in the same position between the reference measurement and the headphone measurement. The hard part is that the headphone cushion presses on the wires and the skin and moves the mic. And because the open canal pressure field has steep spatial structure at high frequencies, a small shift means your two measurements were effectively taken at different planes. So a lot of the variability is really the field being position sensitive combined with the cushion guaranteeing a position change.
To your direct question, I have not done a controlled comparison of different open canal probe designs. What I can speak to is my own near eardrum work, where we placed a mini mic close to the eardrum with an otologist's help. It was very hard to position the mic accurately or consistently across subjects, and the cushions always moved it. So my read is that fixation under a headphone is the harder problem than the sensor itself.
There is also a separate class of semi open designs where the mic is supported by some structure bracing against the canal walls. That opens a different topic which I would rather leave for another time.
Sean Olive shares a tip:
This looks interesting. An inexpensive in-ear microphone to measure and calibrate your headphones.
As we all know, outer ear anatomy causes deviations of up to 20 dB!!! in the perceived frequency response when listening with headphones. The target curve established by Harman and Sean Olive is an "average" curve based on a large population. That curve is meaningless for the individual case due to significant inter-individual variations.
Now, affordable calibration equipment is finally available.
That’s nothing new, though.
As long as 10–15 years ago, there were various threads—including recommendations—discussing in-ear microphone capsules designed to incorporate the individual's own ears into measurements or recordings.
Related topics included the use of these capsules in dummy heads featuring custom ear molds and ear canals, as well as binaural recording using one's own ears for headphone listening.
Has anyone gotten / tried these yet?
Yes — several people have received and tried the Plug by now. I'm the developer, so obviously I'm not the independent person you're looking for, but there is already some user experience coming in.
One research lab that initially bought one unit for evaluation has since ordered two additional units, which was particularly encouraging. There are also several individual users who have been trying them out.
I'm hoping we'll start seeing some independent measurements and reviews soon.
Quick update since my August posts.
EarEqual Plug is now called EarEqual BCR, for Binaural Calibration and Recording. Headphone calibration is still the main measurement use, but there has also been more interest in binaural recording than I expected.
Two things have changed in the hardware and measurement chain since the first units.
The current microphone has substantially lower noise, which matters particularly for recording. More importantly for measurement work, every finished BCR is now individually calibrated and supplied with separate left and right microphone frequency-response calibration files.
I also now have a useful measurement from an independent user. This is a Sennheiser HD 800 measured on one listener:
One important detail: this measurement was made with an earlier BCR, before I started supplying the individual microphone calibration files.
The microphone calibration files matter when the BCR measurement is compared with an external or numerical target, a different measurement chain, another BCR, or when correcting a binaural recording. If the headphone measurement and target are both measured through the same stable BCR microphone/channel chain, the microphone response is common to both and cancels in the ratio, so the microphone calibration file should not be applied.
So the main concept has not changed since August: measure the headphone on the actual listener, with the actual fit, rather than trying to infer that interaction from a standardized fixture.
Of course, none of this accounts for [...] taste, and the degree of listening experience/training — all factors known to influence what we like but seldom reported in headphone reviews. These factors could explain more why a certain frequency response is preferred than the size and shape of our head and ears.
Sorry to budge in with partial off-topic (albeit it concerns the topic IMO) and this question actually has haunted me for a frew days now: how is it possible to reconcile personalized BRIRs with "taste"? I can understand that one might have a preferred "timbre tilt" to the sound, yet it feels quite inconsistent on theoretical side. Pardon me if this is explained elsewhere and published.
If one makes a personalized response (e.g. based on in-ear mics to match in-room speaker HRTF), then how does ear discern timbre coloration from HRTF mismatch? I mean, when one hears off-timbre speaker in the room it will always sound like off-timbre speakers, yet mismatched HRTF causes various types of mislocalized sound and other shenanigans with headphones, not "only" off-coloration. Is it simply the matter of HRTF shape matching the person, as in dips & peaks of whole FR, or what is the magic here?
I hope I got the point across, but basically TL;DR is - in pure theory, can one achieve perfect personalized FR on headphones which realizes off-timbre speakers in a room while not causing any spatial issues? In all honesty, if I got an "you're mixing things here to a big extent" answer then that also is reasonable.
A short remark first, you had a look at the rules for post with commercial interests? Asking because you are supposed to have an ‘audio company' tag.
Sounds great and the calibration is a big step forward, too.
What kind of measurement is in the calibration? Free field of the mic in silicone plug or a boundary measurement where the mic with plug is part of a (flat) surface?
And I have very simple question.
How long is the TRS cable?
And lastly, how good is the BOYA adapter?
Thanks, you're right. I thought the Forum Donor status was sufficient, but I see now that the rules require a separate manufacturer/industry tag. I'll contact @amirm and get that sorted.
The calibration is neither a conventional free-field measurement nor a flat-boundary measurement.
I calibrate the complete finished BCR, including the microphone as installed in the silicone body. The BCR and the calibrated reference microphone are very similar in physical size, so they can be measured sequentially in essentially the same fixture geometry, with only a small difference in the adapter used to hold them. Their sensing positions and orientations are matched as closely as possible.
Because the reference microphone and BCR are measured by substitution in the same fixture, the common source and fixture response largely cancels in the ratio.
The supplied file is therefore an individual frequency-response correction for the finished BCR microphone, including repeatable effects of its mounting and frontal geometry. It is not an absolute SPL calibration or a formal IEC free-field calibration.
The TRS cable is approximately 1 m long.
The BOYA BY-K4 has worked well with BCR in my setup. It provides the required plug-in power and keeps the left and right microphone signals as separate USB channels. It is probably the simplest inexpensive USB-C solution I have found.
BOYA's technical documentation is rather limited, however, and I have not characterized its ADC noise, distortion or channel separation against a professional interface. For headphone measurements it works well, and it is also fine for straightforward binaural recording. If recording quality is the priority, I would use a good recorder or professional interface.
On what it is for: this is individual calibration. The target can be your own reference loudspeakers measured the same way, or a generic target defined at the blocked ear canal entrance. The point is that it is your own ears in the loop, which is the part a population fixture can never capture for you.
That's a very convincing argument :) Consider me a supporter already.
@Marko_EarEqual If someone were to produce a personal target like you mention, how far up the spectrum will that target be accurate for IEMs? I believe the ear canal starts playing a role in the highest octaves.
Thanks for the detailed answers.
I see, that is an option I did not think of: a fixture for both mics (I would call this a ‘boundary condition‘).
However, to me there remain some questions.
I assume the reference mic was calibrated in the free field?
We want from a (calibrated) mic, that a fixed sound pressure at the reference point (capsule entrance) will translate to the same output voltage for all frequencies.
If now the BCR and the reference are compared in the same fixture that makes sense.
But would not the fixture change the frequency response of the reference?
EDIT: More precisely: The reference mic has a flat frequency response in the free field, but the pressure at the membrane area is not flat, because of the baffle step of the ≈12mm circular baffle. So the frequency response in respect to sound pressure at the entrance is not fully flat.
[All this is only relevant for use with externally calibrated signals/HRTF, as you explained.]
What kind of fixture are we talking about? An artificial ear? A ball?
For BCR we already have an EarEqual Reference Target, defined at the same blocked-ear reference plane where BCR measures, at the blocked ear-canal entrance. It is a first version, and I currently expect it to work best with open-back headphones.
The downstream ear-canal transfer is deliberately left outside both the BCR measurement and the target. When BCR is removed and you listen normally, your own ear canal is physically back in the chain, so those resonances return naturally rather than being imposed as an average target feature.
So the difficult HF question is not really how far up the target can remain valid before the ear canal starts to matter. The downstream canal acoustics are already excluded by the choice of reference plane.
The harder region is the upper treble, where pinna and concha variation, exact microphone position, headphone position and measurement repeatability all become increasingly important.
IEMs are different. An IEM sits inside the ear canal, so one should not transfer a blocked-ear headphone target directly to an IEM measurement.
Will read through later. Iam Supporter now as well and told all people i inow about it. But sadly none are interested it seems and see EQ in general as something bad that should not exist. Thats very strange to me as development is based on tech/measurements and science.
I cant wait to understand better why i like something and if its shown in my personal curve and if it helps to correct with personal eq instead of using oratory/resolves eq profiles.
Thank you very much for this product, since i now bought an engame headphone not entirely because it sounds good, but is the most comfortable and best looking out there for me (Meze Empyrean 2). Otherwise i would have choosed the Susvara OG.
The reference is an individually calibrated measurement microphone with its own serial-specific correction file. In our calibration setup, both microphones face the source in the same orientation.
The key point is that the acoustic geometry from the sound source to the microphone membrane is the same for the BCR and the reference microphone. The BCR body and the reference microphone are also very similar in diameter.
So this is basically a dedicated acoustic comparison box. The principle is quite similar to the B&K 4232 Anechoic Test Box. Ours is designed specifically around the BCR geometry, but the basic measurement idea is similar.
Regarding your more precise point: yes, the relevant question is how accurately the reference microphone’s factory correction transfers from its original frontal calibration field into the comparison box. I would expect it to be small in a controlled frontal field, but I would not claim it is exactly zero.
Thank you, and especially for spreading the word. I really appreciate that.
I also find the resistance to EQ a bit strange. It is just another engineering tool, and headphones are already the result of a lot of acoustic tuning.
Your Empyrean 2 is a good example. If you love the comfort, build and design, EQ lets you keep those things and adjust the part that is easier to change.
And yes, comparing what you hear with your own measured response should be interesting. :)
