Hi all. I'm working on acoustic treatment for my home studio and, because I'm in a small, almost-square room, I'm considering using an existing closet as a DIY corner bass trap. I'll attach my REW measurements from my untreated listening position, some acousticmodelling.com simulations I've been running, and a few photos including a floorplan.
The room: 322cm x 346cm with a little nook where the door enters (73cm 97cm). Floor plan attached with color coded walls. Desk is on the red wall. The closet is on the orange wall -- two side-by-side folding door closets, roughly 247cm tall x 73cm deep, sitting essentially in a corner.
REW: Bass is a mess below 200Hz, which is what you'd expect from an untreated room this size. I'm trying to address that before I do anything else.
The plan: I have two closets next to each other, both with bi-fold doors. I'm going to remove one of the doors and fill the closet with insulation to use it as a deep corner bass trap. My acousticmodelling.com simulations suggests that 500mm of porous absorber with a 100mm air gap performs meaningfully better than 500mm flush against the wall, and better still than shallower options. Since the closet is ~730mm deep, I have room to actually do this properly if I leave an air gap behind the fill.
My questions:
If you have time to help me out, thanks in advance!
P.S. I did my due diligence searching for similar posts, but there's a chance I missed it.
My questions:
- Is this a bad idea for any reason I'm not seeing? I'm very new at this. I've been drinking from a fire hose for a week, so I have lots of blind spots. Assuming this isn't a ridiculous idea...
- Is the air gap actually worth preserving, or is filling the entire closet and covering it with acoustic fabric just as effective at these depths? The modeling suggests the air gap matters, but I want a reality check.
- I was going to build a shallow faux bookcase inside the door frame to make this look like a built-in bookshelf -- but if the air gap matters, I probably need that depth. So the bookcase idea might be out. What's a cleaner aesthetic alternative? My current thought is to remove the folding doors entirely and build a simple frame with acoustic fabric stretched over it, making it look like one large intentional panel. Anyone done this well?
- Cost-effective fill options: I don't care at all how it looks inside the closet. Can I just hang standard pink batt insulation from the closet rod/ceiling? Creative ideas for this? I still have to read up on how loose/tight to pack things. I briefly considered blown-in cellulose but I'm not sure that makes sense here because idk how to measure it and prevent gravity from doing it's thing. Long story short, what's the most effective and best product to fill this space?
- How deep do I actually need to go? Is there a point of diminishing returns where I'm wasting money going from, say, 350mm to 500mm of fill?
