Thank you for these -... and this(from the same article)
Note that the Paia "Tubehead" uses the ECC83 (12AX7) twin triode as its "effects generator" as opposed to the Fiio's E88CC (which is a variant of the ECC88/6922/6DJ8 6 V heater, high-mu twin triode and not all that different than an ECC83).
It's an anachronistic product!nearly a handsome unit, but the "R2R TUBE DAC" printed on the front is terrible. I think it's the typeface I find most offensive. Totally anachronistic
your bright headphones are being "warmed" out by the r2r dacs.How do you propose substantiating soundstage and fatigue, both features that are specific to each individual person? Everyone hears both of these things differently, regardless of what any measurement under the sun /might/ try to portray.
I am sharing what I hear and that one amp causes fatigue whilst another does not. That is all I can tell you, people either accept that or they don't. it impacts me 0% how people feel about it either way.
It's like saying Tinnitus can be measured and treated, yet there is no treatment or standard measurement to gauge it, and every person who has it is impacted by it differently.
We're going back straight to the sixties with this one (pun intended).
I love tube gear and the simplicity of the R2R concept, but I'd wager that even being less performant, they still clear at least -70 dB SINAD. In this scenario, and given that they don't have huge quirks elsewhere (or it'd show in multitone, FR and IMD measurements), the actual changes wouldn't produce a substantial change in tonality or sound.your bright headphones are being "warmed" out by the r2r dacs.
if there is a definite, non-subjective audible difference in the tube/r2r i just attempted to give an explanation to it.I love tube gear and the simplicity of the R2R concept, but I'd wager that even being less performant, they still clear at least -70 dB SINAD. In this scenario, and given that they don't have huge quirks elsewhere (or it'd show in multitone, FR and IMD measurements), the actual changes wouldn't produce a substantial change in tonality or sound.
Here in ASR we grew used to <-100 dB numbers because that's the state of the industry due to OP amps and cheap-and-easy NF circuits, but that doesn't mean that the low 70s would sound atrocious or even bad. While not all distortion is equal in timbre, the klippel test perfectly illustrates how little it matters once a good enough relative is reached. This is why we are unbothered by speaker distortion around the mark of 1% or even a bit higher (especially in the low end).
Is that valve bias? ... I had a quick dip into my reading list set by @mhardy6647I love tube gear and the simplicity of the R2R concept, but I'd wager that even being less performant, they still clear at least -70 dB SINAD. In this scenario, and given that they don't have huge quirks elsewhere (or it'd show in multitone, FR and IMD measurements), the actual changes wouldn't produce a substantial change in tonality or sound.
Following this logic, the biggest aspect of the change in sound is actually from bias.
I am not immune to placebo but am more resistant to it than a lot of people i've seen. I experiment with stuff over and over and most conclusions that i've come to, despite subjective biases or not, end up agreeing with research like preference curves aligning with my tastes in different regions and mp3 256+ being transparent
Oh and, wouldn't speaker distortion numbers be less important than headphone ones? Like, headphones are listened at the ear level with direct sounds whereas speakers have room reflections so wouldnt headphones require a lower threshold?
Yes. I own an OTL myself and the experience of turning it on and watching the tubes dimly glow in a dark lit room enhances my listening session, although I know what it's doing to the sound.Is that valve bias? ... I had a quick dip into my reading list set by @mhardy6647![]()
These are all really good points ... what I find interesting is that all these dac units measured here with these incredible measurements are not resulting (for many people) in incredible satisfaction....if there is a definite, non-subjective audible difference in the tube/r2r i just attempted to give an explanation to it.
subjective biases masking actual results then?I understand what you meant, it's just that the whole idea of a H2 dominant signal making the overall sound warmer, IMO, is usually blown out of proportion.
And yes, I think headphones should have a lower threshold, but I don't know if there were actual studies differentiating the two.
seems like people just dont like the sound of their headphones and the differences due to load dependency/distortion change things up just enough to make it all better.These are all really good points ... what I find interesting is that all these dac units measured here with these incredible measurements are not resulting (for many people) in incredible satisfaction....
I put it down to source material. I think I need a switch to switch in an optional R2R and valve chain to handle certain sources and broadcasts.
Well yes, flac vs mp3 etc. is a whole different ball game. I would not tell the difference doing blind switching at the better bit rates. And now as I listen to Amazon Music a lot, an album can switch between redbook and 24/192 between songs and I would have no idea ... nor care a jot. Furthermore, I could listen to two albums mastered differently, both at 16/44 ... but if someone listened to the better master at 24/192 they could understandably attribute the better sounding master to the higher bit rate.seems like people just dont like the sound of their headphones and the differences due to load dependency/distortion change things up just enough to make it all better.
Who knows, maybe it's mr placebo doing his magic. I'm guilty of falling for it whilst testing flac vs mp3 320 and 256.
nothing wrong with having preferencesWell yes, flac vs mp3 etc. is a whole different ball game. I would not tell the difference doing blind switching at the better bit rates. And now as I listen to Amazon Music a lot, an album can switch between redbook and 24/192 between songs and I would have no idea ... nor care a jot. Furthermore, I could listen to two albums mastered differently, both at 16/44 ... but if someone listened to the better master at 24/192 they could understandably attribute the better sounding master to the higher bit rate.
However, after spending an age back in the day converting everything to AAC for portability, it just did not bring happiness. I think our brains do somersaults to interpret and fill in - so longer term feel counts, and quick A/B switching can confuse.
It's not all about warmth!
Valves and indeed certain vinyl recordings can just have more 'pep' - distortion and all ... and I for one prefer 'pep' to 'flat'. There's just too much 'flat'!! Rant over![]()
The worst of both worlds. R2R and tubes. There are better options.
Absolute nonsenseFirstly, because although it does not excel in terms of instrumental performance, R2R conversion technology (when well implemented) brings music reproduction much closer to realism than Delta-Sigma technology, in terms of the Image of the vocalist and instruments and in terms of a credible and almost palpable Soundstage.
Absolute nonsense
The empirical fact that unless by "well-implemented" we mean poorly implemented from a high-fidelity perspective, R2R converters do not have a "sound" that exists outside of your imagination, and neither do delta-sigma converters, because they do not produce audible levels of anything that isn't the unaltered musical signal.Uncomfortable truth or opinion with the same dignity as others?![]()
