.Improved meaning what? Less roll-off?
Please go to Youtube and check it out.
Demonstrating what aspect ?Thats the thing though, im finding lots of talk about this but no actual measurements demonstrating it.
please post before and after measurements that shows better performance after 'hundreds of hours'..
Aging of tubes is well known.
How this pans out in measurements is circuit and tube dependent.
Perhaps somewhere there is someone doing repairs on a tube amp and did before and after measurements.
There won't be any changes due to tubes or capacitors 'breaking in'.Demonstrating the audible changes that occur is what im asking.
The measurements shown here show the warmer has a rather significant bass roll off, i was wondering if this changed over time as the tubes are used as some people are claiming that after a few hundred hours the bass roll off is reduced.
Like i said im just finding it hard to find any actual measurements demonstrating the audible measurable changes that can occur over time.
.please post before and after measurements that shows better performance after 'hundreds of hours'.
And ... that must be when the DAC is connected to the same amp + load.
No measurements = just an opinion.
Looks like the roll-off appears to fit an output capacitor of 2.2uF (7Hz -3dB).
I believe people are hearing this in some cases but their brain tells them its better its warm its tube sound and they convince themselves and they hear better sound indeedTo me it is testimony of how poor the hearing is in gauging 'signal fidelity' and how lenient the hearing is for signal degradation (things like tonal changes and added IM products).
I don't care about the tube buffer in this DAC one bit since I have a tube preamp that I know it have a big impact on the sound I'm getting. I'm actually a bit skeptical if the "warm" sound I'm getting from this DAC is due to tube buffer but mainly it's due to the R2R construction. I did a comparison today multiple times between NOS with no HQPlayer oversampling and HQPlayer with digital filters and I heard a difference in most tracks with heavy orechestra works, Jazz trio works. I can call it natural, warm and analog and you can call it treble roll off which I feel it's a bit rolled off on this DAC.I believe people are hearing this in some cases but their brain tells them its better its warm its tube sound and they convince themselves and they hear better sound indeed
.I don't care about the tube buffer in this DAC one bit since I have a tube preamp that I know it have a big impact on the sound I'm getting. I'm actually a bit skeptical if the "warm" sound I'm getting from this DAC is due to tube buffer but mainly it's due to the R2R construction. I did a comparison today multiple times between NOS with no HQPlayer oversampling and HQPlayer with digital filters and I heard a difference in most tracks with heavy orechestra works, Jazz trio works. I can call it natural, warm and analog and you can call it treble roll off which I feel it's a bit rolled off on this DAC.
Around 45-55 hours..
About how many hours of play time do you have on this DAC?
Yes, the filterless option will be the only sound affecting aspect.I don't care about the tube buffer in this DAC one bit since I have a tube preamp that I know it have a big impact on the sound I'm getting. I'm actually a bit skeptical if the "warm" sound I'm getting from this DAC is due to tube buffer but mainly it's due to the R2R construction. I did a comparison today multiple times between NOS with no HQPlayer oversampling and HQPlayer with digital filters and I heard a difference in most tracks with heavy orechestra works, Jazz trio works. I can call it natural, warm and analog and you can call it treble roll off which I feel it's a bit rolled off on this DAC.
Hours does not matter..
My main concern is the ultra sonic noise, from what I read on this and please correct me if I'm wrong: A NOS R2R DAC implements a low pass filter in the output stage as in a tube buffer like in the case here and that helps not passing those noise to the amplifier and in my case (Class D Purifi amp) which is sensitive to those ultra sonic noises. If that how this DAC works I don't think I have a reason to use digital filters in HQPlayer since I like the sound better with just NOS + no digital filters, if there is a risk passing those ultra sonic noises to a sensitive Class D amp I might need to use the digital filtering in HQPlayer, is that correct?Yes, the filterless option will be the only sound affecting aspect.
The added harmonic AND intermodulation distortion added by the tubes will mostly be masked by the music.
Besides the poorly performing (from a signal fidelity p.o.v.) R2R DAC construction that is nonlinear has a large harmonic spray that unlike the tube behavior adds higher order harmonics and IM products.
Add to that the tube distortion will become less with when the volume of the signal decreases but the distortion from the R2R non-linearities will become relatively worse the lower the signal is.
There is a reason why the specifications are quoted at -6dB FS out... it may be much worse at 0dBFS and FiiO might not wanted to publish that number.
At some point in time it will be properly measured most likely.
The bass roll-off also won't be an issue in your case as usually tube pres have a high input resistance (usually around 100k).
Choosing OS or using HQplayer solves the 'roll-off' from the sample-and-hold errors.
Fortunately... the hearing is quite insensitive for this kind of 'changes to the sound' (depends on the recording a bit too).
The looks are great though which means half the battle is already won.
NOS dacs do not use low-pass filters, which is the whole idea behind their design. Instead of filtering, they rely on a simple "step-and-hold" process (zero-order hold) to reconstruct the signal. This creates strong ultrasonic images that can leak into later stages of the audio chain. While some NOS designs add a very gentle analog low-pass filter, it is generally not strong enough to meaningfully suppress this ultrasonic content.My main concern is the ultra sonic noise, from what I read on this and please correct me if I'm wrong: A NOS R2R DAC implements a low pass filter in the output stage as in a tube buffer like in the case here and that helps not passing those noise to the amplifier and in my case (Class D Purifi amp) which is sensitive to those ultra sonic noises. If that how this DAC works I don't think I have a reason to use digital filters in HQPlayer since I like the sound better with just NOS + no digital filters, if there is a risk passing those ultra sonic noises to a sensitive Class D amp I might need to use the digital filtering in HQPlayer, is that correct?
Late reply and a complete? aside, but my cheap-n-humble SMSL SU1 easily reproduces production and mixing differences...I'm not sure I've seen a measured DACs that does something more exciting that rolling off either some amount of treble or bass, or adding faint levels of distortion. I think that calls for DSP, not swapping converters.
Personally, I think if you want to home-remaster your music, sticking it into a DAW and futzing around with the reams of eq and distortion and dynamics plugins you can find is both a more fun and more productive activity.
Yes.My main concern is the ultra sonic noise, from what I read on this and please correct me if I'm wrong: A NOS R2R DAC implements a low pass filter in the output stage as in a tube buffer like in the case here and that helps not passing those noise to the amplifier and in my case (Class D Purifi amp) which is sensitive to those ultra sonic noises. If that how this DAC works I don't think I have a reason to use digital filters in HQPlayer since I like the sound better with just NOS + no digital filters, if there is a risk passing those ultra sonic noises to a sensitive Class D amp I might need to use the digital filtering in HQPlayer, is that correct?
Thanks, one question though does this applies to PCM 44Hz only? Meaning if I feed PCM 44Hz files after the digital filtering and upsampling in HQPlayer but PCM files higher than that like 192Hz or more and DSD files directly to NOS mode in the DAC those files are immune to those ultrasonic noises correct?Yes.
In NOS mode there will be a LOT of ultrasonic crap in the signal. It is the 'mirrored' image of the sound (mirrored at 22.05kHz or 24kHz in most cases).
Inaudible by itself as we can't hear anything there but the ultrasonics could potentially be a bit problematic in some cases.
You can even spot some of it here (look closely at the 'noise' in the higher frequencies)
Note: headphones and the used test fixture will have filtered out most of it but it will surely be there.
There usually is a very slow (6db or 12dB/octave) low pass in there above 40kHz or so to get rid of the MHz crap but that won't do anything for the crap that might damage tweeters (when playing really loud) or might interfere with the modulator of class-D amps.
The latter (when it is a good one) should have a steep low-pass at its input to prevent this but.. you never know.
Best NOT to use NOS mode (simulated or not) when using class-D amps for sure.
In fact best to not use that mode at all. If a gentle roll-off is your thing do that filtering digitally before it hits the DAC.
It is not exactly the same effect but comes close.
Best to use OS mode in this DAC anyway.
The whole NOS thing is a gimmick but people ask for it so the manufacturers provide.
They don't care if, in rare cases, it might cause an issue. It won't in most cases anyway.
Manufacturers only care about selling as much as they can to an as wide as possible audience.
