Same here. And this is independent of phones and IEMs; the hissing is just stronger with low imp IEMs.got the B. just tried it out now. loud hissing on the IEM i have on hand on 4.4. couldnt get it to stop hissing. will try on another phone when i get home.
No, this is not a DAP (Digital Audio Player).I'm wondering if it would be possible to connect a usb drive (to access flac files) with an otg adapter to the usb port on the tiny A version?
You’re obviously correct if you wonder about Tiny-A as a USB host—it is not a DAP; where the power would come from?No, this is not a DAP (Digital Audio Player).
Okay, got it, this is an interesting questionYou’re obviously correct if you wonder about Tiny-A as a USB host—it is not a DAP; where the power would come from?
I believe @DazST question is about the auxiliary USB-C “power” port: besides the charging pass-thru feature, can it be used as an OTG port for your phone (not Tiny-A!), e.g. with a USB drive? This is a good question…![]()
I did a few tests with a laptop and a DAP (didn't have a USB drive & OTG adapter. After plugging Tiny-A into my laptop and looking at the USB information, it does see an audio device (Tiny-A), an HID interface, but no USB hub.I'm wondering if it would be possible to connect a usb drive (to access flac files) with an otg adapter to the usb port on the tiny A version?
Yes, that is indeed what I meant. Sorry for not making it clearer.You’re obviously correct if you wonder about Tiny-A as a USB host—it is not a DAP; where the power would come from?
I believe @DazST question is about the auxiliary USB-C “power” port: besides the charging pass-thru feature, can it be used as an OTG port for your phone (not Tiny-A!), e.g. with a USB drive? Put it another way, is Tiny-A a USB hub?
Thanks for testing it. I decided to order one of these (Tiny A) myself so when it arrives I'll try it with a usb thumb drive.I did a few tests with a laptop and a DAP (didn't have a USB drive & OTG adapter. After plugging Tiny-A into my laptop and looking at the USB information, it does see an audio device (Tiny-A), an HID interface, but no USB hub.
I can charge my DAP (or iPhone) from Tiny-A plugged into my laptop. Power goes: Laptop > Tiny-A > DAP / iPhone.
If I plug Tiny-A into my DAP (or iPhone), I can definitely charge my DAP (or iPhone) from a charger with the pass-thru feature. Power goes: Charger > Tiny-A > DAP /iPhone. I didn't try to charge my laptop as I think to remember Tiny-A has a fairly low power limit.
So, Tiny-A "aux. port" is a bi-directional power pass-thru. But I don't think it can carry data, Tiny-A is not a USB hub.
can you share spacetouch eq tool?A picture of FiiO Snowsky Tiny B (left), Fiio Jiezi (4.4mm version) and, for reference, CIXUN USB-C to XLR cable (reviewed by Amir a few weeks ago) internals:
Tiny B and Jiezi use a SpaceTouch SPV4040 USB bridge/DSP/DAC/Amp.
Tiny B:
Jiezi:
The CIXUN cable is one of these, now common, TTGK CB1200AU. I included it here as it is allegedly a custom version of that SPV4040 (Side note: the CIXUN cable is WalkPlay-enabled, offering 8x PEQ filters).
Perhaps more interesting (at least to me!) is Tiny B little IC on the left of SPV4040:
Difficult to read, but I believe it's a HT97220 from "Heroic Technology". I didn't know this chip, it's a very-compact low-power, single-ended amplifier with integrated charge pump—see attached datasheet (pdf, in Chinese). I'm not sure if it feeds both the 3.5 and 4.4mm outputs on Tiny-B (haven't checked the ports wiring), but you can use both 3.5 and 4.4mm ports at the same time (this, I checked with two headphones).
Most likely doable... as soon as FiiO/Snowsky publishes a firmware update for Tiny A/B...AFAIK, no FW update is available yet. Another approach would be to craft a Tampermonkey script to deceive the FiiO Control WebApp—making it think the JM11 is a Tiny A or B (see this post for an example with WalkPlay and NiceHCK Octave: https://www.audiosciencereview.com/.../nicehck-octave-dongle-dac.65535/post-2433992)
In the meantime, I checked JM11 with the SpaceTouch (production-intent) EQ tool, and yes, it has 8x PEQ filters available:
It’s available as part of the Configuration Tool, SDK, etc. available at : http://8.140.228.49can you share spacetouch eq tool?
thanks, also LibUsbDotNet also making flash tool workIt’s available as part of the Configuration Tool, SDK, etc. available at : http://8.140.228.49
The Configuration Tool zip file download was flagged by my PC as containing a Trojan (Win32/Suschil!rfn). I did the extract in a Sandbox, and the files were scanned as virus free.
You need to install LibUsbDotNet for the EQ tool to work.
