FiiO / Snowsky Melody not loud enough (HD560s)
L5730
East of England
Hi all,
Maybe I'm doing something wrong or being particularly dumb.
I just can't seem to get adequate playback volume from this DAC/amp through Sennheiser HD560s.
I have Tempotec Sonata HD Pro, also using a single similar CS43131 DAC chip and no separate amplifier(?) and the specs look similar.
I'm not even tricking the SHDPro into 'high gain' mode with the open extension lead, power on, plug in headphone trick. It's just louder.
I'm using the single ended 3.5mm socket on the Melody, don't really fancy spending for a balanced cable.
Melody 3.5mm spec.
2.3V peak
100mW @ 32 ohm
13mW @ 300 ohm
Sonata HD Pro spec.
2V Peak (high impedance) else 1V
66 mW @ 33 ohm (measured)
14mW @ 300 ohm (measured)
Amir's review:
I'd hazard to guess the Melody should be similar in output level into the same headphones.
Any input is appreciated.
It's me being dumb or installing the ASIO driver for Windows10 has made a big difference.
It's now got PLENTY of output power!
Edit again:
I dunno, if I set the EQ to 0 dB and flat, it seems like I need to max the dongle out. That gives little room for adding EQ.
More testing to do I think.
I dunno if this applies to all FiiO devices, but that difference in volume when EQ is turned on to when it isn't sounds like 6 dB ish, so it makes sense that they auto reduce the gain by 6 dB giving some headroom for boosting EQ. I don't know what the headroom is in processing terms for transients, I doubt a limiter is applied.
This reduction of 6 dB though (to boost low end for HD560s) puts it right at the edge of usable volume when using -18 LUFS ReplayGain target.
Oh well.
You can increase the master gain / global gain slider on the EQ interface (A preamp value of -x dB corresponds to 12 - x dB on FiiO's master/global gain slider).
But I'd also just buy a balanced cable, I got the 4.4mm version of this very nice one for only AU$14 (it's shorter than the stock HD 560s cable, but feels much nicer)
(Don't waste money on the official AU$110 one from Sennheiser)
The downside is that you can't get a balanced cable with buttons & a microphone, only 3.5mm supports that (I use such a cable with my phone).
plenty of affordable ones on aliexpress but then again, choice is yours to miss out on the benefits.
