roladyzator
- Joined
- Feb 4, 2023
- Messages
- 220
- Likes
- 274
You do not need the KA15 for that purpose alone. Just get the SMSL PO100 or the BerryBak Bea1 to convert USB audio to S/PDIF.I was thinking about KA15 for a different reason, this little thing has optical SPDiF out. I got the JM20MAX, plenty of volume for the AUX input, but the sound is brighter/dirtier than most of sources capable of CD playback in analog mode. But with KA15 I could use USB to SPDiF conversion to run my Denon's AVR BB DACs.
Regarding the DRE and Connexant distortions , good some manufacturers pay attention to the issue. Also huge thanks for giving the issue more publicity - I bet more people look at the ASR reviews than they pay attention to what Roman has to say on given topic.
The SPDIF output is not optical - it's coaxialI was thinking about KA15 for a different reason, this little thing has optical SPDiF out. I got the JM20MAX, plenty of volume for the AUX input, but the sound is brighter/dirtier than most of sources capable of CD playback in analog mode. But with KA15 I could use USB to SPDiF conversion to run my Denon's AVR BB DACs.
If you boost given range of freqs by given amount of dBs, you need to lower the overall level by the same amount to prevent DAC overload and very ugly distortions, normally you would want max level never hitting the 0dB, but more like -3dB, -1dB max. And this works for every digital system. Some EQs automatically lower the preamp volume when the EQ is applied. Never saw PEQ lowering level more than it is needed to prevent DAC clipping, and I don't Fiio does it differently.Hi. Sorry if I can't get my point across. Kinda new in the audio hobby. Hoping you all are having a great day. I'd like to know how much dB's the PEQ on the KA15 lower down by default. I don't get it because by default just using the PEQ already lowers down the volume from what I can hear so it wouldn't be necessary to lower down any further in the global gain depending on what you are using. Thanks.
12dBHi. Sorry if I can't get my point across. Kinda new in the audio hobby. Hoping you all are having a great day. I'd like to know how much dB's the PEQ on the KA15 lower down by default. I don't get it because by default just using the PEQ already lowers down the volume from what I can hear so it wouldn't be necessary to lower down any further in the global gain depending on what you are using. Thanks.
+12 dB pregain in the FiiO Control app and website is actually no change in volume.Hi. Sorry if I can't get my point across. Kinda new in the audio hobby. Hoping you all are having a great day. I'd like to know how much dB's the PEQ on the KA15 lower down by default. I don't get it because by default just using the PEQ already lowers down the volume from what I can hear so it wouldn't be necessary to lower down any further in the global gain depending on what you are using. Thanks.
These improvements would be great. I'd also noticed that the global gain in the PEQ truncates the decimal part, for example if you put -8.3 the next time you load the profile it just says -8Based on @roladyzator's excellent summary of issues and my measurements of the Q parameter effects, I believe the following is a list of functionalities we want to ask FiiO to improve or implement:
@Amperage: Can you make this happen?
- Unwanted behavior due to its sleep mode:
- A loud pop is generated when the KA15 goes into a sleep mode a few seconds after playback is stopped. This occurs especially when the KA15 is connected to a high-impedance input like an amp or active speakers. There's a workaround like holding volume down before connecting to USB that prevents it from entering sleep; however, with this method it still enters a certain kind of sleep and generates some noise.
- There's a skip of a half second when playback (re)starts from its sleep. The behavior of the KA15 is less desirable compared to other devices according to these tests.
- Suggested fix: Either improve its sleep mechanism, or if it's too much trouble, at least give the user greater control over its sleep behavior. For example, battery saving options like (a) Full, (b) Medium, (c) Off may be added. We do understand FiiO incorporated effective battery saving through its sleep mode (possibly multiple stages). However, due to its unwanted effects, some users simply do not need this feature (e.g., connected to a computer).
- Incorrect Q parameter of shelving filters:
- The high and low shelf filters are described with Q, but the Q factor value is not interpreted as such by the app. It seems to actually be taken as a "shelf slope" or S parameter. For example, to have an effect of Q = 0.707, the user have to enter Q = 1.0. This incorrect translation was measured here. The Q factor has a clear, technical definition. It should not be mistaken as the S parameter.
- Suggested fix: Revise the code to use an appropriate formula. The easiest fix would be simply converting user input of Q to S = sqrt(2) x Q.
Another issue is below:Based on @roladyzator's excellent summary of issues and my measurements of the Q parameter effects, I believe the following is a list of functionalities we want to ask FiiO to improve or implement:
I have a KA17 and tbh the PEQ UI is utterly grim. It's the most painstaking process in the android app, however be that as it is, I've not altered the preamp gain as I assumed this was auto (like toneboosters in uapp), I guess not?If you boost given range of freqs by given amount of dBs, you need to lower the overall level by the same amount to prevent DAC overload and very ugly distortions, normally you would want max level never hitting the 0dB, but more like -3dB, -1dB max. And this works for every digital system. Some EQs automatically lower the preamp volume when the EQ is applied. Never saw PEQ lowering level more than it is needed to prevent DAC clipping, and I don't Fiio does it differently.
I went with SMSL PO100 Pro. Satisfied for now. I was surprised how small the unit is. To me via optical things sound way more natural than by using JM20MAX and line input on Denon AVR.You do not need the KA15 for that purpose alone. Just get the SMSL PO100 or the BerryBak Bea1 to convert USB audio to S/PDIF.
I've been following a few different threads, and just to confirm:Based on @roladyzator's excellent summary of issues and my measurements of the Q parameter effects, I believe the following is a list of functionalities we want to ask FiiO to improve or implement:
- Suggested fix: Either improve its sleep mechanism, or if it's too much trouble, at least give the user greater control over its sleep behavior. For example, power saving options like (a) Full, (b) Medium, (c) Off may be added. We do understand FiiO incorporated effective power saving through its sleep mode (possibly multiple stages). However, due to its unwanted effects, some users simply do not need this feature (e.g., connected to a computer).
Yes, there is a -12 dB volume reduction. 0 dB gain in FiiO UI apps is -12 dB instead of 0 dB.I've been following a few different threads, and just to confirm:
Peak filters are fine on the KA15, but high and low shelf filters need their Q values converted through S = sqrt(2) x Q?
Also on the KA15, I've heard that Fiio automatically applies -12 dB volume reduction on PEQ, so you don't need the preamp settings, perhaps? I messed around with my LCD-2C settings, and I went from virtually maxing out volume to get something listenable to having a solid amount of headroom by getting rid of most of my preamp reduction.
I didn't measure this earlier. Just confirmed this is true. FiiO made a really bad decision---as usual their design is not thoughtful. Why on earth block the precious upper gain range by a whopping 12 dB? Sure, the KA15 is relatively powerful but still some users have chosen it to drive relatively insensitive headphones. In that case some softly recorded material may require near-max device volume when EQ is applied.Yes, there is a -12 dB volume reduction. 0 dB gain in FiiO UI apps is -12 dB instead of 0 dB.
You're right. It was my mistake in calling their implemented parameter "shelf slope (S)". In fact, it is not. Their parameter simply = sqrt(2) x Q. That is, their implemented "Q" parameter is proportional to actual Q by a constant factor of sqrt(2). I verified it.The relationship between S and Q is more complex. Unless S is 1, it also depends on the gain. Look for words "The relationship between shelf slope, S
, and Q" in the Audio EQ Cookbook document.
But I'm not sure what exactly FIIO is following. Perhaps more measurments of expected vs actual filter shape are needed to confirm what is the nature of the error
I think it is an area where FiiO is definitely lacking. They appear to make very good hardware, but that’s their problem: they focus too much on the HW, struggle to support it with good SW, and end up with poor implementations or sloppy details.as usual their design is not thoughtful.
