FiiO KA11 Portable DAC/Amp Review
Rate this portable DAC & HP Amp
    Votes: 4 1.8%
    Votes: 3 1.3%
    Votes: 34 15.2%
    Votes: 182 81.6%
This is a review and detailed measurements of the FiiO KA11 portable stereo DAC and headphone amplifier (USB-C). It is on kind loan from a member and is on sale for US $33.
I didn't think there was room to make a stylized dongle but here is FiiO, doing exactly that. Attention was even given to the 3.5mm headphone jack with its white color and such.
Above you see it with my USB-A adapter which I used for testing but is not included with the unit (the plug is USB-C as mentioned).
Note that there is no volume control in the unit. And on Windows, for some reason, all of these devices start with very low volume even though Windows says "100%." You need to change the volume and yet again set it to 100 to get max volume.
FiiO KA11 Measurements
I must say, I was not prepared for such excellently low noise and distortion from this little device:
Distortion is vanishingly low and slightly above nominal voltage output puts the KA11 squarely in desktop class performance and well above many dongles:
Noise alone does the same thing:
As does jitter:
Ditto for multitone:
FiiO KA11 Headphone Adapter dongle DAC amp amplifier Multitone Measurement.png
I was however disappointed with the slow filter:
It should attenuate by 24 kHz and not 26.
Fortunately frequency response is correct:
FiiO KA11 Headphone Adapter dongle DAC amp amplifier frequency response Measurement.png
Again, IMD results are more than what I could ask for in such a tiny device:
Max power is also very respectable:
FiiO KA11 Headphone Adapter dongle DAC amp amplifier Power 300 Measurement.png
FiiO KA11 Headphone Adapter dongle DAC amp amplifier Power 32 Measurement.png
Who would have thought that we can get such incredible performance in such a small and low cost package? Beyond the small (bug) of DAC filter, the rest of the KA11 performance is amazing, leaving no room for any complaining. And the thing dares to be attractive to boot!
Happy to recommend the FiiO KA11 DAC and headphone amplifier.
  • FiiO KA11 Headphone Adapter dongle DAC amp amplifier Power 300 Measurement.png
  • [Hi-Fi Audio Performance]: This USB C to 3.5mm audio adapter delivers high-fidelity audio performance with a Hi-Res DAC chip that provides excellent and stable decoding performance. It supports a maximum sampling rate of 32bit/384Khz, which is higher than most other USB C headphone adapters available on the market.
  • [DAC Chip for Hi-Fi Sound Quality]: Built-in with high-peformance DAC CS43131 and op-amp allows the KA11 to effortlessly produce great Hi-Fi sound.
  • [Lightweight but useful and powerful]: The tiny USB DAC KA11‘s body size is only 44x9.7x10.5mm, and it is just about 8.5g. It is convenient and portable for you to take it anywhere. The power can reach 245mW at 16Ω load and 200mW at 32Ω load, which is enough to drive most headphones.
  • High-standard circuit components are supplemented by multi-layer immersion gold circuit board design, with strong decoding ability and better detail control. THD+N: <0.0006% SNR: 125dB Noise: <1.7uV
  • [Multi-playing ways and portable]: KA11 amplifier with a USB Type-C/Lightning connector, you could use it on Android/iOS phones and tablets or to Windows and Mac computers to get a high resolution sound for listening music, playing game, doing chatting, doing living when you are at home or at office.
  • [UAC1.0 support]:In the UAC1.0 mode, devices such as Switch and PS5 can be plug-and-play, allowing you to not only enjoy a low-latency gaming experience but also restore rich and detailed gaming sound effects, enabling you to quickly immerse yourself in the game. *Note: The UAC1.0 mode needs to be switched in the FIIO Control app.
Very nice.
Worth to mention.
It has PEQ built in. You can use web app or phone app to control it.
It seems like KA11 does not offer PEQ.
Sorry for the inconvenience.
Respectable little device. Thanks for testing, Amir. I think you double posted the power vs. distortion graph instead of the IMD graph.
Is there anything it does better than the other CS43131 dongles out there? I will need to go back and check.
What is the latest verdict about the gain switching that happens in these DACs to get better S/N whether it has any practical / audible impact? Is that the little blip that shows up at 0.3 mW (300 R) or 2.5 mW (33 R) in the power vs. distortion graphs?
Oops. Fixed.
Utterly amazing the performance you can get in a small low cost product such as this.
I would really love to see a blind test set up involving a bunch of the usual suspects between this and one of the "high end" dacs at 500 times the price. :p
Have they dealt with this problem properly ?
The CS431xx series of chips have a curios distorsion problem see tread .
Looks like it (compare with fourth chart in your link)
EDIT - as has been pointed out down thread this is not the same test signal as chart four in the link - it is more comparable with the 2 tone test signals - albeit in the test here done with higher frequency tones.
Yes, it's possible these performance figures will be poorer if the audible DRS distortion is disabled.
Worth to mention.
Actually I don't think this one has PEQ - the much less powerful JA11 has PEQ and then the larger KA15 and above have PEQ.
While it amazing having this power in such a small device, I did find, with this dongle, that it does pull allot of power from your smartphone pretty fast so your battery will die after a few hours usage.
Ooops.
Yes it seems like it lacks PEQ.... damn, good to know I was 100% sure that it offers it like other Fiio devices.
Shame on me.
ps. I wanted to buy it because of that.... oh well
The JCally JM 20 Max is cheaper with slightly better performance.
It also drains the battery quickly, as mentioned by Jeromeof. I would choose them for use with a PC, but for a smartphone I'd go for something like the CX31993 or similar DAC. Low power consumption, lower price, and the measurements are transparent as well.
