First thing I noted about JM20-Max: it does get hot! Not like burning hot, but definitely noticeable.Nice, let us know if it shows any issue, hopefully not.
As @HissingFree said, it can be a good sign, the SGM opamp clearly generates some heat and the dongle chassis is correctly dissipating it. The point is if the dissipation is enough in the long run.First thing I noted about JM20-Max: it does get hot! Not like burning hot, but definitely noticeable.
very usefull thanks, this was made high gain+desktop mode on, did you also do the measurements in low gain desktop mode off ? i am trying to figure out what setting to put to get the best sound quality on low impedance high efficiency iems that requires only low power ( my hype4 is already loud enough at volume 30/120 in low gain desktop mode off, but i read that most reviewers claims ka17 sounds better in high gain desktop mode on)FiiO KA17
I only have a 30 Ohm dummy load, so my measurements show that the best THD+N is -109 dB (0.00034%) at -12 dBFS, which is about 45 mW of output power.
This is also equivalent to 0 dBFS and a volume of 36 (out of 60) on the device itself.
View attachment 392366View attachment 392367
Unless those other reviews have some measurement data then their opinions aren't worth much, so in this instance you can only make that judgement using your own ears. Personally I'd assume that if you can get away with less gain then potentially your snr and dynamic range would be higher and you use less battery energy.very usefull thanks, this was made high gain+desktop mode on, did you also do the measurements in low gain desktop mode off ? i am trying to figure out what setting to put to get the best sound quality on low impedance high efficiency iems that requires only low power ( my hype4 is already loud enough at volume 30/120 in low gain desktop mode off, but i read that most reviewers claims ka17 sounds better in high gain desktop mode on)
yes that makes sense, i remember my topping g5 in low gain mode sounds flat and dull even if i raised volume to match loudness i got in medium gain which made no sense but i confirmed it with my own ears, that don't seem to be the case with ka17 (low gain+desktop mode off don't sound worse than high gain+desktop mode on) i guess this come from the different type of amp used in topping g5 vs ka17Unless those other reviews have some measurement data then their opinions aren't worth much, so in this instance you can only make that judgement using your own ears. Personally I'd assume that if you can get away with less gain then potentially your snr and dynamic range would be higher and you use less battery energy.
Oddly, I have to use it in high power mode to drive all of my iems and full size.
No, this comes from your own hearing. Unless you can provide data (measurements) or references to data supporting your claim…i guess this come from the different type of amp used in topping g5 vs ka17
don't think so because for ka17 i read everywhere that desktop mode sounds better but i don't hear it and for g5 i also read everywhere that low gain was flat and lifeless and indeed it was, if placebo/expectations worked for g5 it should have worked also for ka17. not every aspects of the sound are captured by one measurement. it is very obvious for iems that can sounds completely different even though they have a similar frequency responseNo, this comes from your own hearing. Unless you can provide data (measurements) or references to data supporting your claim…
This is just your opinion. Completely respectable, but nothing more than an opinion.don't think so because for ka17 i read everywhere that desktop mode sounds better but i don't hear it and for g5 i also read everywhere that low gain was flat and lifeless and indeed it was, if placebo/expectations worked for g5 it should have worked also for ka17.
You're correct about 'one' measurement. But every aspect of a recorded sound/music (I'm not talking about hearing or perception where the human brain get involved...) can be captured by measurements: if we can record a sound--mankind has developed the technology--what aspect of that sound can't we measure?not every aspects of the sound are captured by one measurement.
You're mixing two different things. G5 is way beyond "transparent" as far as audio reproduction and, although not measured here, I suspect KA17 is also completely transparent.it is very obvious for iems that can sounds completely different even though they have a similar frequency response
it's not that we can't measure, it is more that multiple different measurements is harder to sell and understand than a single grade to help choose. for iems we have frequency response but we never give measurements such as impulse response time ( that varies per driver type, what do you do for tribrid iems, you give 3 numbers ?) . having multiple measurement dimensions is not practical and does not guarantee we covered all aspects of sound in the measurements ( there are discussions about influence of infra sounds and ultrasounds on human sound perception)You're correct about 'one' measurement. But every aspect of a recorded sound/music (I'm not talking about hearing or perception where the human brain get involved...) can be captured by measurements: if we can record a sound--mankind has developed the technology--what aspect of that sound can't we measure?
Frequency response and impulse response are two different representation of the same thing: when you have one, you can mathematically calculate the other.for iems we have frequency response but we never give measurements such as impulse response time
The FR measurement of an IEM addresses ~80 (making the number up) of what we need to know about that IEM. Add distortion measurements, and there is not much “unknown” left.having multiple measurement dimensions is not practical and does not guarantee we covered all aspects of sound in the measurements
Yes there are discussions… From what I have read, ultrasounds may cause some measurable brain activity spikes. Whether it correlates to the sounds we can hear and participate in our like/dislike of a particular track is not even close to be established and accepted. So why worry about something with no practical relevance?there are discussions about influence of infra sounds and ultrasounds on human sound perception
i did not knew that. how do you explain that 2 iems that graphs similar can sound differentFrequency response and impulse response are two different representation of the same thing: when you have one, you can mathematically calculate the other.
FR is generally easier to grasp.
I think what’s going on is that the test fixture impedance characteristics and your ear canal acoustic impedance characteristics are not the same. Therefore, two IEMs may measure the same on a given test fixture (they have the exact same FR or have been EQ’d to graph exactly the same), but yet respond slightly differently when exposed to a different acoustic impedance—your ear canal.i did not knew that. how do you explain that 2 iems that graphs similar can sound different
Whereas I don't have that problem, the spatial cues are much the same for iems closed and open back over ears.My issue with IEMs is just how congested the sound is, like if I separate them slightly from my ears, obviously it sounds less congested but then I lose most of the bass. With Over Ear Headphones one can get at least some soundstage and localization, while retaining bass if it's a closed back.
No matter how expensive an IEM is, it cannot beat the physical limitation of IEMs, that is, the sound always comes from inside the ear.
iem are know for having less soundstage than headphones but what iem were you using ? when a/b test hype4 to mega5est, price difference is only $150 but imaging and soundstage is much better on mega5est so there are differences, hype4 was like a 2D wall of sound in front of you but mega5est had different sound position in spaceMy issue with IEMs is just how congested the sound is, like if I separate them slightly from my ears, obviously it sounds less congested but then I lose most of the bass. With Over Ear Headphones one can get at least some soundstage and localization, while retaining bass if it's a closed back.
