Fiio K7 powered by usb
reisub83
Hi
I see from the official spec that the power supply of the K7 is outputting 12V 2A
Anyone know if it will be possibile to power the K7 with an USB powerbank and a step-up converter cable 5V to 12V 2A ?
These step-ups converter cables are usually really poor quality.
Instead, try to find a Powerbank with USB PD support. You can then get a USB-C to Barrel jack PD Trigger to get native 12V out of the power bank.
It will be very complex to step up a DC power source (step up usually refers to AC power). Also the USB power would be insufficient. I bought the following linear power supply (Aliexpresss) for my K7 and am very happy:
Bump.
Would I be able to power this with a 12v supply from a suitable leisure battery/12v boat hook-up? ie. with a 12v charge controller. Thanks in advance.
