FiiO K7 BT vs TOPPING DX3 Pro+ for Hifiman Edition XS?
mkmoss
As in the title I have Hifiman Edition XS's and am looking for an amp for them as well as for possible future purchases.
Topping about $100 cheaper in Canada. Any reasons I wouldn't get it over the K7?
As far as I can tell they would both have plenty of power for the XS's.
I chose these two amps specifically because I'm looking for something with bluetooth.
Also I tested out the FiiO KA11 and it does get the XS's loud enough. I'm wondering if I might still notice an improvement in sound quality with a higher priced amp even though the KA11 gets them loud enough?
Thanks!
Not really.
Yup, more than enough. The EDXS is a very sensitive headphone.
Properly level matched, there will not be an improvement in sound quality.
Not really.
Thanks for your reply.
I'm not quite sure what you mean by properly level matched?
If one Amp plays slightly louder than the other, then it will almost always sound better in an A/B comparison.
Match the output levels precisely and that goes away.
How would I match the output level with a dongle like the KA11?
Use a basic multimeter to measure the output voltage and whatever volume control is available to you and precise enough for this purpose.
staticV3, how does the K7BT drive the hifiman Sundara headphones. Do you prefer the K7BT over the K11 R2R? Thanks
