Fiio K5 Pro or Drop O2 + SDAC
MathewC
I live in the EU and ordered the O2 + SDAC but now see that it only has a US plug and the EU plug will either be $16+$26 shipping, or $23 in an EU store. For this price it will be around the same as the Fiio K5 Pro. I see that the Fiio has a stronger Amp but want to know if the Amp is better, the DAC is better and any other features which are better or different than the O2 + SDAC. Which will give me better sound?
The amps are about equal. The SDAC is a bit better than the DAC of the K5 Pro. The only "features" I can think of is the LED around the pot of the K5 Pro, which changes colour based on the input you're using.
Assuming the O2 doesn't have a pot with audible channel mismatch, they should sound the same.
So should I just stick with my choice of the O2 SDAC then? It will probably arrive after September and the Fiio could be quite a bit faster to get.
Fiio 5k pro is available in EU?
Both of these are not available anywhere in the US. Damn!
