The exact expected result. The inferior measurements are not sufficiently inferior to make an audible difference.On paper, the R2R has significantly inferior measurements. But I couldn’t hear any difference.
If you are really interested in finding out if you are hearing is really due to the filter - and not perceptive bias, the only way is to set up a properly controlled DVM level matched blind test (you'll need a friend to help - and you'll need to spend some effort to make sure your controls are adequate - for example not being able to interact in any way with your friend during the test). See if you can spot the same sound stage differences when you have no idea what filter is being used. See if you can repeat that achievement 10/10 times.I appreciate the technical breakdown, but I have to respectfully disagree based on my own measurements and hands-on testing.
I’m pretty meticulous about my chain. I run Adam D3V speakers EQ’ed to flat from 50Hz to 10kHz using a measurement mic, and I’ve EQ’ed my LCD-X (and even the DT 1990 for kicks) to match that same flat response using pink noise as a reference. I’ve even gone the extra mile of building a DIY in-ear microphone to measure exactly how my own ear geometry and headphone placement affect the frequency response in real-time.
With all that data in front of me, I still find the NOS setting provides the widest perceived soundstage. In NOS, the instruments—especially high-hats—don't feel like they are playing "inside" my head; they sit just outside the cups with a slightly "fuzzy" or airy quality that feels more natural to my ears.
As for the "treble roll-off" argument: I don't actually see a significant drop-off in the highs on my measurements specifically due to NOS. In fact, moving the headphones even 1 cm on my head changes the frequency response more than switching the filter does. If there is a roll-off, it’s negligible compared to the physical fit and seal of the pads.Short story is that it does something, I just can measure it...
At the end of the day, I’m taking a chance on the K13 for the R2R implementation, but even if the "magic" is subtle - of any, the onboard EQ options and the remote are worth the admission price alone.
Yup. I did my tests *before* visiting this forum. I had got the R2R DAC because an AI recommended it for a different sound.The exact expected result. The inferior measurements are not sufficiently inferior to make an audible difference.
Fair point on the perceptive bias—it’s the reason I actually sat down with my wife yesterday for a blind test.If you are really interested in finding out if you are hearing is really due to the filter - and not perceptive bias, the only way is to set up a properly controlled DVM level matched blind test (you'll need a friend to help - and you'll need to spend some effort to make sure your controls are adequate - for example not being able to interact in any way with your friend during the test). See if you can spot the same sound stage differences when you have no idea what filter is being used. See if you can repeat that achievement 10/10 times.
If you are going to do more testing, you need to check accurately (to 0.1%, with a test signal, and DVM at the speaker or analogue output) the levels. It is possible with all the noise and distortion the NOS mode introduces, that it could make a level difference. This will impact your perception in a way. that is simple level related.Fair point on the perceptive bias—it’s the reason I actually sat down with my wife yesterday for a blind test.
I had her switch the filters while I stayed completely "blind" to the settings. Interestingly, I was able to distinguish between Filter 2 and NOS every single time.
However, I'll be honest: switching between the other oversampling filters and NOS was a total hit-and-miss for me. There's definitely a specific delta between Filter 2 and the NOS mode that my ears (and my music—mostly dense symphonic metal and "fantasy" tracks) pick up on immediately in terms of that spatial "fuzziness" I mentioned.
To put some data behind my madness, I’m going to spend tonight finalizing the graphs. Tomorrow, I’ll post the measurements from the K11 using my DIY in-ear mic across the different filter settings.
As I said before, I’m seeing more variance in the frequency response just by shifting the headphone cups a few millimeters than I am from the filters themselves, but the measurements should at least give us a baseline for what’s happening at the eardrum level. Either way, the K13 is on route!
That is not a surprise. And it invalidates your tests if the cups move even a little bit between comparisons. Even tilting your head might make a difference that swamps filter differences.As I said before, I’m seeing more variance in the frequency response just by shifting the headphone cups a few millimeters than I am from the filters themselves,
There, fixed that for you. It's a large part of what this forum is for.![]()
I didn't say I was looking for how it SOUNDS. I know what this forum (and a majority of members) are about.Turns out, when it comes to DACs, measurements tell us everything we need to know about how they sound. Ownership has no value exept for telling how good it feels to touch.
Master Thread: Are Measurements Everything or Nothing?
Seems like so many review threads get challenged with: 1. Measurements are not everything. 2. You all never listen. 3. I trust my ears, not graphs. 4. I don't listen to graphs. I listen to music. 5. You all must not listen to music at all. 6. Why don't you all buy the best SINAD gear? 7...www.audiosciencereview.com
The glitch that has been mentioned here earlier, is it has a LO mode that is 100%, if you connect the K13 to a power amp and use that mode on the unit or accidentely on the remote it will send 100% to your speakers.I didn't say I was looking for how it SOUNDS. I know what this forum (and a majority of members) are about.
I cam here looking for problems, glitches, things that work well (and things that don't), user EXPERIENCES, etc.
Thank you to those that ACTUALLY contributed with user experience, rather than simply bashing.
If the statement "the inherent nature of R2R DACis is that they are not as accurate as delta sigma dacs" meets your definition of "bashing" as opposed to "a summary of reality" - then go right ahead.Thank you to those that ACTUALLY contributed with user experience, rather than simply bashing.
I don't have a K13, but I have the Fiio Tiny and Melody, and their PEQ implementations have some bugs, listed here.I didn't say I was looking for how it SOUNDS. I know what this forum (and a majority of members) are about.
This is clearly one of the best stacks available for any price regardless 101,000 I put in some Holland 6DJ8 (Amperex). Silence and I can put this back up against anything under $2000.If anyone owning Fiio R2R Warmer seeing this - Does it has pop on power ON/OFF?
My god rge spellling. My apologies. Quad of Amperex 6DJ8 is reasonable, NOS- matched. My spelling was awful. Let’s have itThis is clearly one of the best stacks available for any price regardless 101,000 I put in some Holland 6DJ8 (Amperex). Silence and I can put this back up against anything under $2000.
I'm not sure if this is applicable to the K13 R2R. I tried to convert two different APO configs, one with low shelf filters and one with peaking filters.I don't have a K13, but I have the Fiio Tiny and Melody, and their PEQ implementations have some bugs, listed here.
I suspect the same bugs may occur on the K13 as well.
I've also had lots of annoying issues with the Fiio control app and website (loading a saved EQ profile incorrectly sets the names of the on device ones, the EQ switch on the website doesn't work, sometimes when playing with the EQ there is some clicking noises added to the sound, but disconnecting/reconnecting my DAC fixes it; sometimes the APP just fails to change anything on the DAC, again a reconnection fixes it, I could go on but those are the most annoying).
I suspect this may be a bug in the K13 R2R.I'm not sure if this is applicable to the K13 R2R. I tried to convert two different APO configs, one with low shelf filters and one with peaking filters.
Both of these produces a lot of artifacts/clipping. Whereas when I put them in manually into Fiio Control (not taking your conversions into account) they change the sound more or less the same way as they would do through APO on my other DAC.
Here's the filters, unfortunately I do not have time to measure anything. I read some reports from other users which states that clipping and artifacts can occur with EQ if the master gain is not matched (in negative) of the highest filter gain. I tried to lower the master gain on the generated EQs and the clipping was gone.I suspect this may be a bug in the K13 R2R.
If you can share your EqualizerAPO filte file, I can see if my Fiio dac's also have this problem, and if there's something wrong with my script.
If you want to be extra helpful, you could use Room EQ Wizard and measure the output of the K13 R2R (connect a cable from an output port to a line in or mic port on your computer), with your converted EQ profile active, and again with your hand made one. Oh and with APO EQ but K13 R2R without EQ as well.
Preamp: -4.0 dBFilter 1: ON PK Fc 30 Hz Gain 4.0 dB Q 0.500Filter 2: ON PK Fc 170 Hz Gain -2.5 dB Q 2.000Filter 3: ON PK Fc 400 Hz Gain -1.0 dB Q 2.500Filter 4: ON PK Fc 700 Hz Gain -1.5 dB Q 1.500Filter 5: ON PK Fc 1700 Hz Gain 3.0 dB Q 1.600Filter 6: ON PK Fc 16500 Hz Gain 3.0 dB Q 1.000Preamp: -6.7 dBFilter: ON LSC Fc 55 Hz Gain 2.5 dB Q 1Filter: ON LSC Fc 120 Hz Gain 4 dB Q 1Given that choice - me too.the choice is a no-brainer for me!
