Fiio K11 (non r2r) RCA output + spdif coaxial output together?
dasherzx
Hi, i was wondering if there are any Fiio K11 users who can check if it's possible to use the RCA out and coaxial output simultaneously. Reason being that id like the coax out to go into a dsp monitor while the rca goes to a subwoofer. I have a topping d10s on order which ive read that could do both together. So i was wandering if a K11 could do it too + i get a headphone amp at the same time.
Is there a digital Coaxial output on this DAC? And did someone test it? Not many DAC's have digital outputs.
Old thread, but perhaps someone has a similar question...
The coax in from the K11 can configured as coax out for USB resources.
Obviously coax out and line out will get a signal together, only the line out can controlled in the volume.
So it's not really a solution for active speakers and an active sub, because it will be hard to get here a synchronized volume control.
