Fiio JT7 cable
Donuts123
I have a Fiio JT7 on order and was wondering about getting a replacement cable for it (shorter and more flexible).
The cable supplied with the headphones has two 3.5mm TS (not TRS) connectors on the headphones end. Whereas some other Fiio headphones have 3.5mm TRS connectors.
If I get a cable which has TRS plugs on the end, will that just work, or do I need to find a replacement which has the same TS plugs as the original?
Bit late reply but you can use trs for it. I made a custom cable and it just works with trs ends.
