FiiO IMP XLR-4 Power Amplifier Impedance Adapter
Jeromeof
Ireland
This seems like an interesting product idea, I would love to see Amir test this one:
From FiiO Marketing:
FIIO IMP XLR-4 power amplifier impedance adapter is specially designed for power amplifiers. It solves the problems of noise and the risk of damaging the headphones when high-power amplifiers directly drive headphones. By absorbing excess power and purifying the noise floor, it unleashes powerful driving force, allowing you to freely connect headphones to your amplifier. Unlock new application scenarios for your amplifier and enjoy high-quality sound with peace of mind.
Dedicated for power amplifiers: Handles high-power output, absorbs excess power, and purifies the noise floor; compatible with over-ear headphones such as the JT7/FT7 and mainstream HiFi power amplifiers such as the EA13.
Dual balanced outputs: Features two balanced output interfaces—4.4mm + XLR-4. A single adapter supports a wide range of balanced headphones, eliminating the signal loss and additional coloration often caused by adapters.
Voltage-dividing circuit: Safely handles high-power output while mitigating amplifier noise, making it easy to drive low-impedance, high-sensitivity headphones.
Gold-plated copper binding posts: The copper base offers excellent conductivity, minimizing signal loss and distortion. The gold-plated layer offers stable oxidation resistance for reliable, long-term connectivity.
Aluminum alloy housing: Provides superior physical shielding to reduce electromagnetic interference and ensures stable operation through efficient heat dissipation. It features a solid build and refined craftsmanship.
dual transformers, centre-split at output, I assume, like a DI?
Only £27 - but a +version that had a built-in switchable Y-split to allow speakers or 'phones might also be useful. It would need L + R output posts of course.
Yes - I built one to take the speaker output of my guitar amp into a second amp's (pre) input. The transformers are common as audio car parts. But this for £27 is fair enough. Not sure what "purifying the noise floor" means... Flash/Lysol?
That is so Zeos, he enjoys to to pair headphones with speaker amps.
