Just received the JCally JM12 from AliExpress. Unfortunately---I don't know if this is normal---its stock firmware's max volume is set to -6 dB. So, it seems that I have to flash the TinHifi or JA11 firmware just to solve this volume issue alone.
Before I flash the FW---no going back to stock FW---, I measured its response using the KTmicro tool's temporary fix of the volume. But I found that it is difficult to get steady signals from it. See below:
There is absolutely no setting that controls this behavior. It is just random---I can see these erratic responses come and go on rolling FFTs.
Same for the multitone signal:
I initially thought I had received a defective unit. But going over this thread I found another ASR member (@trungdtmc)'s measurements of the FiiO JA11 in this post. The JA11 also showed a similarly distorted multitone response:
I suspect that these measurements explain all the erratic listening test results reported in this thread. I guess I will see the same results even if the TinHifi or JA11 FW is flashed.
