Is anyone else having this issue of being unable to properly switch between saved profiles?Well the 2.0 update has completely broken the android app PEQ for me. I can set a single profile and save it to the device and that seems to work, but loading profiles that I created and saved to the device is not working at all. I select a different profile and it "loads" but no changes are made to the PEQ, or sometimes random changes are made but nothing close to the actual saved profile.
To clarify, I make the following EQ and save it to device:
Preamp: -1.5 dB
Filter 1: ON PK Fc 20 Hz Gain 1.5 dB Q 1.200
Filter 2: ON PK Fc 470 Hz Gain 0.9 dB Q 0.800
Filter 3: ON PK Fc 2200 Hz Gain -3.3 dB Q 1.300
Filter 4: ON PK Fc 3300 Hz Gain 1.1 dB Q 2.000
Filter 5: ON PK Fc 4600 Hz Gain -3.1 dB Q 2.000
Then if I hit reset to 0 everything out and try to reload this EQ which I just saved, I see this and must completely remake the EQ from scratch (so the saved profiles are completely broken on mine):
