Sha1rholder
Quite different.I wonder if the diaphragm is similar to the one used in XK Serene\Susvara
Still can't find measurements for these anywhere but maybe I'm not looking hard enough
tbh I don't trust any measurements not made by Amir mostly because the others are being made subjectivists on non standardized rigs with no protocol incentivized to present pretty looking measurements and thus are often presenting overly smoothed measurements to hide imperfectionsThere are a few measurements for these on squig.link already. They look pretty good so far.
You can trust sai.squig , Oratory, listener , hangout.audio/crinacles and resolves, they all know what they're doing and have proper equipment, if not the same as amirm (GRAAS 43AG)tbh I don't trust any measurements not made by Amir mostly because the others are being made subjectivists on non standardized rigs with no protocol incentivized to present pretty looking measurements and thus are often presenting overly smoothed measurements to hide imperfections
Oratory's measurements are for EQ not for review, I guess I should have specified I meant within the context of reviews. The rest absolutely are as I described, presenting overly smoothed measurements to hide imperfections, some don't even post distortion measurements or present them (and frequency responses) in misleading ways. Harman's research was done on the GRAS but reviewers are increasingly talking about the B&K 5128 as being superior to the GRAS and switching to it misleading people into thinking the GRAS Harman curve is 1 to1 to their approximation of the curve on the B&K. Amir and Oratory are the only ones actually following the scienceYou can trust sai.squig , Oratory, listener , hangout.audio/crinacles and resolves, they all know what they're doing and have proper equipment, if not the same as amirm (GRAAS 43AG)
The only one who is misleading here is you.Oratory's measurements are for EQ not for review, I guess I should have specified I meant within the context of reviews. The rest absolutely are as I described, presenting overly smoothed measurements to hide imperfections, some don't even post distortion measurements or present them (and frequency responses) in misleading ways. Harman's research was done on the GRAS but reviewers are increasingly talking about the B&K 5128 as being superior to the GRAS and switching to it misleading people into thinking the GRAS Harman curve is 1 to1 to their approximation of the curve on the B&K. Amir and Oratory are the only ones actually following the science
The FT1 Pro which uses a very similar driver (or at least one with the same dimensions) had either QC or design flaws which caused the bass to clip with harmon bass boost. Your review of that headphone didnt show that, but at least the FT7 not compressing by 1db in the bass is reassuring.My FT7 review is up.
FT7
back to FiiOback to measurementshome Published: Apr-06-2026, updated May-01-2026 NO SMOOTHING is applied to the shown plots. Most measurement sites have some smoothing applied which ‘irons flat’ sh…diyaudioheaven.wordpress.com
The drivers of the FT7 are quite different in construction.
It is a seriously good sounding planar magnetic headphone that really only needs to have the 8.5kHz peak lowered about 5dB.
This will 'smooth' the treble.
I could turn up the volume very high on the FT1pro and JT7 and could not 'clip' it.
Perhaps an amp or digital signal was clipping ?
Maybe a specific unit had an issue ?
Actually, Sai at unheardlabs experienced clipping even earlier on the JT7. According to him, he reached out to Fiio and they also confirmed it was a real QC issue known to them. https://unheardlab.com/2026/02/15/fiio-jt7-review-a-budget-disruptor-or-a-bridge-too-far/Acc. to FiiO this only occured on some (returned) early production models.
This was their first foray in planar magnetics.
When your copy is like this I would contact FiiO and get it replaced.
This all does NOT apply to the FT7 and most likely also not to the JT7 (again different driver).
The FT1 PRO I tested did not have this issue at that time.
