FiiO FT1 eq tips.
  • FT1_PeaceEQ.zip
From
Preamp: -3.8 dB
Filter 1: ON PK Fc 65 Hz Gain 1.3 dB Q 1.908
Filter 2: ON PK Fc 154 Hz Gain -4.3 dB Q 1.000
Filter 3: ON PK Fc 1050 Hz Gain -1.2 dB Q 3.966
Filter 4: ON PK Fc 1826 Hz Gain -2.3 dB Q 2.509
Filter 5: ON PK Fc 2787 Hz Gain -4.6 dB Q 2.252
Filter 6: ON PK Fc 3135 Hz Gain 6.6 dB Q 1.105
Filter 7: ON PK Fc 6122 Hz Gain -5.6 dB Q 3.873
Filter 8: ON PK Fc 6857 Hz Gain 4.2 dB Q 5.542
Filter 9: ON PK Fc 7865 Hz Gain 0.7 dB Q 1.000
Filter 10: ON PK Fc 12536 Hz Gain -2.7 dB Q 3.000
  • FT1 Plompudu_.zip
FiiO FT1 Harman 2018 EQ
From https://vsg.squig.link/headphones/?share=Harman_2018_Target,FiiO_FT1
Preamp: -5.5 dB
Filter 1: ON PK Fc 20 Hz Gain -3.5 dB Q 0.900
Filter 2: ON PK Fc 130 Hz Gain -3.8 dB Q 0.800
Filter 3: ON PK Fc 1100 Hz Gain 2.2 dB Q 1.700
Filter 4: ON PK Fc 2300 Hz Gain -3.1 dB Q 0.700
Filter 5: ON PK Fc 3800 Hz Gain 6.3 dB Q 2.000
Filter 6: ON PK Fc 4400 Hz Gain 1.4 dB Q 2.000
Filter 7: ON PK Fc 5600 Hz Gain -6.0 dB Q 2.000
Filter 8: ON PK Fc 6500 Hz Gain 7.9 dB Q 2.000
Filter 9: ON PK Fc 7500 Hz Gain 3.9 dB Q 1.200
Filter 10: ON PK Fc 8100 Hz Gain -8.2 dB Q 2.000
Filter 11: ON PK Fc 10000 Hz Gain 4.3 dB Q 2.000
Lite version
Preamp: -5.5 dB
Filter 1: ON PK Fc 20 Hz Gain -2.24 dB Q 0.900
Filter 2: ON PK Fc 130 Hz Gain -2.43 dB Q 0.800
Filter 3: ON PK Fc 1100 Hz Gain 1.41 dB Q 1.700
Filter 4: ON PK Fc 2300 Hz Gain -1.98 dB Q 0.700
Filter 5: ON PK Fc 3800 Hz Gain 4.03 dB Q 2.000
Filter 6: ON PK Fc 4400 Hz Gain 0.9 dB Q 2.000
Filter 7: ON PK Fc 5600 Hz Gain -3.84 dB Q 2.000
Filter 8: ON PK Fc 6500 Hz Gain 5.06 dB Q 2.000
Filter 9: ON PK Fc 7500 Hz Gain 2.5 dB Q 1.200
Filter 10: ON PK Fc 8100 Hz Gain -5.25 dB Q 2.000
Filter 11: ON PK Fc 10000 Hz Gain 2.75 dB Q 2.000
Preamp: -4 dB
Filter 1: ON LSC Fc 300 Hz Gain -1.8 dB Q 1.500
Filter 2: ON PK Fc 806 Hz Gain 1.0 dB Q 3.000
Filter 3: ON PK Fc 1800 Hz Gain -2.0 dB Q 1.000
Filter 4: ON PK Fc 4063 Hz Gain 4.0 dB Q 1.500
Filter 5: ON PK Fc 5270 Hz Gain -2.0 dB Q 2.000
Filter 6: ON PK Fc 6545 Hz Gain 4.0 dB Q 4.000
Filter 7: ON PK Fc 7777 Hz Gain -2.0 dB Q 2.000
Filter 8: ON PK Fc 8700 Hz Gain -1.5 dB Q 2.000
Filter 9: ON PK Fc 9950 Hz Gain 1.0 dB Q 4.000
Filter 10: ON PK Fc 11666 Hz Gain 2.0 dB Q 4.000
Filter 11: ON PK Fc 13280 Hz Gain 2.0 dB Q 3.000
Filter 12: ON PK Fc 14060 Hz Gain -2.0 dB Q 4.000
Today I am using this one :)
Preamp: -4 dB
Filter 1: ON LSC Fc 333 Hz Gain -1.7 dB Q 0.700
Filter 2: ON PK Fc 1200 Hz Gain 1.3 dB Q 1.700
Filter 3: ON PK Fc 1800 Hz Gain -2.8 dB Q 2.500
Filter 4: ON PK Fc 3600 Hz Gain 1.0 dB Q 1.100
Filter 5: ON PK Fc 3900 Hz Gain 4.0 dB Q 1.100
Filter 6: ON PK Fc 4500 Hz Gain -5.6 dB Q 0.800
Filter 7: ON PK Fc 6900 Hz Gain 3.8 dB Q 0.800
Filter 8: ON PK Fc 8100 Hz Gain -5.6 dB Q 2.200
Filter 9: ON PK Fc 10000 Hz Gain 3.4 dB Q 1.300
Filter 10: ON HSC Fc 12000 Hz Gain -1.5 dB Q 1.700
@HoJ76 EQ for what (programe or type of EQ) and wanting it to sound how?
Play with Auto-EQ.
And I mean play with it!
Tip: stress them out below 30 Hz, leave a little bit over Harman from 100 Hz down, do the mid bass to the target strictly (so that they don't sound boomy).
I can elaborate if must be.
Play with Auto-EQ.
Yes, please do!
Yes, please do!
They can't do good below 30 Hz so it's better to make them do better above it. If it stays above the target from 100 Hz it will sound boomy. I have similar headphones with very similar drivers if not the same (Denon AH-D5200).
Preamp: -2 dB
Filter 1: ON LSC Fc 50 Hz Gain -1.0 dB Q 1.000
Filter 2: ON PK Fc 120 Hz Gain -3.0 dB Q 1.000
Filter 3: ON PK Fc 444 Hz Gain 1.0 dB Q 1.000
Filter 4: ON PK Fc 1111 Hz Gain 1.0 dB Q 2.000
Filter 5: ON PK Fc 3000 Hz Gain 1.2 dB Q 2.000
Preamp: -2 dB
which EQ is this? Do you have a peace file for this? thank you! =)
Equalizer APO https://sourceforge.net/projects/equalizerapo/
Peace Equalizer https://sourceforge.net/projects/peace-equalizer-apo-extension/
Copy the text to a TXT file and import to Peace EQ or import from the attached TXT files, Fiio FT1_1.txt is the one you asked.
Some more :)
Preamp: -4 dB
Filter 1: ON PK Fc 20 Hz Gain -2.0 dB Q 0.700
Filter 2: ON PK Fc 44 Hz Gain -0.6 dB Q 3.000
Filter 3: ON PK Fc 120 Hz Gain -2.0 dB Q 1.100
Filter 4: ON PK Fc 210 Hz Gain -0.8 dB Q 2.000
Filter 5: ON PK Fc 420 Hz Gain 1.1 dB Q 1.500
Filter 6: ON PK Fc 840 Hz Gain 0.7 dB Q 2.400
Filter 7: ON PK Fc 1600 Hz Gain -1.8 dB Q 1.800
Filter 8: ON PK Fc 4000 Hz Gain 1.0 dB Q 2.000
Filter 9: ON PK Fc 5200 Hz Gain -7.0 dB Q 2.500
Filter 10: ON PK Fc 5600 Hz Gain 2.6 dB Q 0.900
Filter 11: OFF PK Fc 7000 Hz Gain 2.0 dB Q 4.000
Preamp: -4 dB
Filter 1: ON PK Fc 21 Hz Gain -0.7 dB Q 3.000
Filter 2: ON PK Fc 58 Hz Gain 2.5 dB Q 2.200
Filter 3: ON PK Fc 120 Hz Gain -1.7 dB Q 1.700
Filter 4: ON PK Fc 350 Hz Gain 1.3 dB Q 1.200
Filter 5: ON PK Fc 1400 Hz Gain -0.7 dB Q 0.800
Filter 6: ON PK Fc 2500 Hz Gain 1.8 dB Q 3.000
Filter 7: ON PK Fc 4000 Hz Gain 2.3 dB Q 2.400
Filter 8: ON PK Fc 4500 Hz Gain -2.0 dB Q 1.700
Filter 9: ON PK Fc 5400 Hz Gain -8.4 dB Q 3.000
Filter 10: ON PK Fc 6100 Hz Gain -3.2 dB Q 3.000
Filter 11: ON PK Fc 6500 Hz Gain 4.8 dB Q 2.500
Filter 12: ON PK Fc 6800 Hz Gain 3.5 dB Q 1.200
Filter 13: ON PK Fc 14000 Hz Gain -8.2 dB Q 3.000
  • Fiio FT1_1.txt
  • Fiio FT1_2.txt
  • Fiio FT1_3.txt
Really appreciate the reply. :D
Ok, I use it equalizer APO and the Peace GUI already...I thought the squig was a different graphic EQ but now realize its some kind of separate online frequency tuner...I really don't know how to use this but man its fun to play with frequencies! are you just tuning the bands one by one to match the curve of desired target?
I didn't know all I had to do was save it in a txt file and then import it...peace converts to a .peace! love it! Thanks again.
Has anyone used FXSound to EQ their FT1s?
No.
One more :)
Preamp: -4 dB
Filter 1: ON PK Fc 20 Hz Gain -1.5 dB Q 2.000
Filter 2: ON PK Fc 175 Hz Gain -2.0 dB Q 2.000
Filter 3: ON PK Fc 250 Hz Gain -1.2 dB Q 1.600
Filter 4: ON PK Fc 420 Hz Gain 0.6 dB Q 1.600
Filter 5: ON PK Fc 888 Hz Gain 1.0 dB Q 2.000
Filter 6: ON PK Fc 1777 Hz Gain -2.4 dB Q 2.000
Filter 7: ON PK Fc 4000 Hz Gain 2.0 dB Q 2.000
Filter 8: ON PK Fc 6545 Hz Gain 3.5 dB Q 3.000
Filter 9: ON PK Fc 8000 Hz Gain -4.0 dB Q 1.300
Filter 10: ON PK Fc 10500 Hz Gain 2.5 dB Q 2.000
