Ravitester
- Joined
- Mar 4, 2022
- Messages
- 4
- Likes
- 1
I am having a problem with my Fiio BTR7. The firmware is 2.02, the Fiio control app on android is 3.21 and Tidal android version is 2.114.0.
I connect the DAC to my phone via usb cable (rather than bluetooth) and use the tidal app on my phone. The headphone output is plugged into the aux input of the amplifier and speakers in the car.
To play MQA files I have turned off the normalise volume in the app and have been playing MQA tracks fine, with MQA showing as the replay mode.
The problem arises when the tidal playlist contains music encoded as flac (showing as PCM on the Fiio) then the music replay stops! If I try another MQA track in the same playlist it will play, but I have to restart the BTR7 to get it to play PCM files.
It seems it is struggling to switch between files formats, via usb and keep playing the tracks. Is this a know problem or better is there a solution?
A reddit post says
this a well known issue that has been going on for some time with the native tidal app. It's been this way for at least 6 months.
It's a 'bit-perfect' bug. As far as i know, it affects most (if not all) DACs
Is that right?
A reddit post says
Is that right?
