Do you mean "more powerful than" a Wiim?- Surely powerful than Wiim Amp, as I have both and checked
As I said there, Wiim Amp.Do you mean "more powerful than" a Wiim?
Wiim Ultra Amp ?
3e A7 and PAM153 are my favorites ones, I have them.> As good as any other well measured TPA3255 amplifier, I have many
3e A7 Mono on 51V 10A PSU x2 is (I think here widely acknowledged as?) top Wrms power out of all the rest, for those with big rooms and thirsty speakers who want every last dB SPL
plus it has a solid PFFB implementation which many consider important.
Definitely.Of course if/when Amir gets a unit to measure...
Evidence?I think it has a proper PFFB implementation, unlike the Level 1 which I don't think had even though the marketing said it did
3. I don't think the PEQ in implemented correctly - sharp narrow Q Values are still very wide ( at least in my brief in room measurements)
- No subwoofer crossover
I already have extensive support for FiiO devices in my devicePEQ tool => https://github.com/jeromeof/devicePEQYou might want to read this thread.
I have built lots of special compensation for various issues with different PEQ hardware implementations - I also have written a test harness that I have shared with some manufacturers to help => https://www.pragmaticaudio.com/devicePEQTestHarness/Cool. Does this software automatically bypass the weird /√2 issue?
Too bad, not a competitor to WiiM AMP....- No subwoofer crossover
Depends if you need it or not, normally active subwoofers have crossover already.Too bad, not a competitor to WiiM AMP....
It needs a high pass filter for the subwoofer out to be useful. Otherwise your small speakers will try to play all the way down to 20 Hz if you like me have an 18" subwoofer connected and use Dirac to make it go all the way down. I tried this with a Fosi ZA3. At first I couldn't understand why I got endless amounts of port noise from my Elac DBR62 and the bass drivers bottomed out at moderate levels, but then it dawned on me. The Fiio has the perfect size and looksm but this is a massive omission and I struggle to find something that can compete with a Wiim Ultra Amp.Depends if you need it or not, normally active subwoofers have crossover already.
No clue myself, but I simply see subwoofer out as a plus with a stable streaming platform and good amplifier with app as well as remote functionality.Maybe they can to add High Pass Filter via firmware ? or this need to be implemented in hardware ?
PEQ works very well.Many chinese amp do not have this, most of them, this FiiO have PEQ EQ which is big advantege.
Does PEQ support all filters type, like HP, HPQ etc ?No clue myself, but I simply see subwoofer out as a plus with a stable streaming platform and good amplifier with app as well as remote functionality.
