Fidelio AW9000/10 parametric equalizer with Wiim pro plus
marcelP
Hello :)
This is my first thread, usually I find everything I need on this forum, but this time it's a bit different ;)
I would like to know if anyone knows where I can find some parametric equalizer setup for the speakers Fidelio AW9000/10 (Fidelio A9)? I just bought the Wiim pro plus, and connected it by RCA. I found the sound a bit of sometimes, especially in high frequencies.
Thank you very much!
Are you asking what EQ settings should be used for those speakers? if so, I don't see any data of their frequency response on ASR. I suppose you could troll the internet looking for some data, then try to correlate that with what you are hearing and design an EQ 'fix'...
