Fidelia — bit-perfect macOS music player (developer intro, measurements welcome)
Right - got it. I have mocked up a generic audio input as I agree that would be quite useful as a method to use the Fidelia engine, processing, and multichannel calibration for other sources.
As far as LMS->WiiM, another way you could do it would be to browse the LMS directly in the Fidelia library and select the WiiM as its output device (it can play directly to streamers - this method works today). To play Roon audio through Fidelia, though, you would need the aforementioned input selection.
I have to say I love how forum discussions so effectively inform where this should go vs. just design in a vacuum; thanks for your time.
An update, since this thread has been quiet since September and a lot has shipped.
Fidelia for iPhone and iPad came out in September on the same engine: bit-perfect to a USB DAC, gapless, HeadSpace crossfeed, and the ten-band EQ with a parametric side that imports AutoEQ profiles as written (filters, Q and preamp). On the Mac, 2.13.3 is current as of this writing.
The parts this forum can check:
• View ▸ Meters shows sample peak and RMS for every channel. RMS uses a 300 ms window and the AES17 reference, so a sine reads its peak level.
• Filter Phase: Minimum leaves no pre-ringing, and Linear keeps timing even across the band.
• DR, R128 loudness range and volume level, and ReplayGain values that JRiver or Audirvana wrote into files are read (not computed) and shown as sortable columns.
• On iPhone, Bridge streams the Mac's library, including away from home over a VPN. When a link measures too slow for a track above the phone's output rate, the Mac sends a 16-bit FLAC copy at that output rate, TPDF-dithered, multichannel folded to stereo. It's not used with Bit-Perfect or Follow File Rate on, and Signal Path names it, e.g. "Reduced stream: 16-bit/48 kHz from 192 kHz".
The idea is, you've got your own library with you everywhere. No "server", no cloud, no data tracking, no subscription.
Measurements are still welcome.
Cheers!
Patrick
