Ferrum Audio Wandla - teardown
whydan
As my first impression of Ferrum Audio, that should be HYPSOS power supply with hybrid design.
HYPSOS has interesting design which I don't like it, but we still can see the digital control is good.
OOR headphone amp and ERCO DAC with hp come after HYPSOS, now is WANDLA
There are three edition of WANDLA, pure DAC, Goldensound edition and DAC with HP AMP.
This WANDLA is pure DAC which borrowed from my friend.
You can see "Fe" logo and color touchpad screen on front panel.
The rear panel, XLR / RCA output and RCA input, I didn't know why RCA input until I found the HP amp config. Rest are AES/COA/OPT/USB/I2S/ARC/Trig and two power input. It's rare to see USB-C and HDMI ARC on DAC. Those two power input design for bundle selling their PSU product.
The bottom side, actually the top/bottom cover should be SPCC. The feet used rubber foot and I believe they should use better foot than regular rubber foot in this price.
Inside, it can sperate as 5 parts. The left area is power source, and upper area is I2S/ARC input board.
Digital processing board is in the center, right upper area is volume control and input/output buffer and the DAC circuit are in the lower right area.
There is no component on back side, only trace routing and vent hole.
Touch panel, it seems the use customized components like FPC cable with IC and will be a problem on 3rd party repair.
Power input side, the jump wire on the 4pin connector should be CANARE 4S6, then go to SMD fuse with socket on PCB. There is another one SMD fuse for DC-in jack but didn't show on photo. Rest components used for control power on/off like MOS, then go Pule PA2743NL choke as system power. BTW, if you connect power cord then connect adapter to DAC then you may see a small sparkle on DC-in jack. That's why the designer add lots of TVS diode as protection on power input stage.
There are many power sources after power choke, it used two sets of LT8641 for ±17V then go LDO as analog power source.
There are two sets of LT3088+LT3090 after LT8641 for ±15V separated for left and right channel components.
It's rear to find this separated power design, I saw different stage but none of them used for different channel.
I can only guess this designed for better crosstalk performance but I am not sure.
Crosstalk should be related to layout routing and volume control, less concern from power.
5VA used LT8609A and C-L-C-L-C filter on output, it should be the solution to reduce ripple peak on different frequency after measurement. The digital 5V power source used LT3757 which means they built a Flyback SMPS on board, probably for higher current and higher efficiency. This DAC will get hot after work couple of minutes, I think MCU may take lots of loading on filter.
Digital control board, used SMSC USB PHY USB3315, SPDIF DIX4192 and ST HDMI2C1-6C1 for ARC.
Then go to STM32 MCU for DSP, and one VCXO on board probably used for PLL of MCU. Rest one 24Mhz used for USB3315.
There is another 49Mhz on back side of digital control board, it should use for DIX4192 but that don't meet requirement on datasheet. The line driver DS90LV032A used for I2S signal.
DAC chip ES9038pro and his partner, Ref clock used ABLNO 100Mhz which is as good as CCHD-950
AVCC used ES9311Q, rest 1.2V and 3.3V used ADP151ACPZ, textbook level design on DAC power.
But it's rare to find THS3112 on I/V OPA except in some threads of DIY forum. Then 2pcs BUF634A per channel as buffer that looks more like a headphone amp. The one after BUF634 is OPA1632 as LPF. To be honestly I am not fully understanding whole design here.
DAC output connect to AXICOM relay to switch signal between RCA input and DAC, then do analog volume control by MUSES72323. The output buffer of MUSES72323 is LT1364 then go to upper side relay.
The upper relay may use for signal switch between output and headphone board in another SKU.
Output buffer used LT1364 and OPA2182 as DC servo, the designer likes to use high speed OPA.
RCA input buffer used LT1364 then OPA1632 invert as balanced signal, then go back to relay before volume control. I don't know why to add an RCA input in the beginning until I find another edition with headphone AMP on website when writing this review.
RCA connector used unusual type and looks shining, but actually I took this photo to explain the output signal connection. RCA and XLR hot used same signal just separate by resistor. It may be conflict when connect both RCA/XLR in the same time.
A quick test for THD+n, ADC is Cosmos ADC Grade B and Topping HS02 USB Isolator.
The result is around 111.5dB, the noise floor is a bit higher than rest SOTA DAC because designer didn't pick those ultra low noise OPA like OPA1612.
Let me know any you have any question on this report, thank you.
WANDLA, eh? Someone must be a fan of IKEA.
I'd suspect that the feedback network is on the low impedance side for noise concerns, necessitating the use of buffers to avoid degrading the distortion performance.
I would rather think that it's the PGA (MUSES72323) volume control at fault here. Which obviously means that all the effort put into low noise on the DAC side may be for nought... perhaps a case of the left hand not knowing what the right is doing? Is this the maximum output level you could get out of it? Is there possibly some setting to bypass the volume control?
Suffice it to say that I would be very disappointed if I could only get a 111.8 dB SNR out of an ES9038PRO. This is basically an order of magnitude lower than what it would be capable of. Do things improve at all at -60 dBFS?
Thanks for this insight, @whydan !
For reference: This unit is about 2800 € (inc. VAT) / 2750 USD (before taxes). For that amount of money, I would expect the absolute best performance possible.
Is it audibly transparent: Yeah, looks like it. Is it flawless or at least best in class: No. An RME ADI 2 DAC FS performs better, has more features, excellent support and costs less than half. Maybe the RME's case isn't quite as nice as this, but still.
(Yes, I know: Most ASR users are not the target demographic for this.)
I don't get your point actually, maybe I am not a fan of IKEA haha.
it sounds reasonable, because it weird to add lots of buffer stage in one DAC, the final output one is the important one in my opinion .
Thanks for reminding, I checked the datasheet of MUSES72323 and the noise floor is around -140dB when mute.
I already tested on maximum output and it can't bypass MUSES72323 regarding to current design.
There is a bypass setting in setup menu but I don't think that is what you looking for, because the physical trace can't bypass MUSES72323.
I agree that 111.8dB SND is a bit low than I expect but I returned this DAC to my friend, so I can't provide further test.
I don't think this one is a transparent sound type, it's more coloration that other SOTA DAC like D900 I owned.
Designers take lots of effort on filter and DSP tried to sound not boring which may fail you if you are seeking a transparent sound.
RME may be a better sound if you want a transparent sound DAC.
@whydan,
I would like to thank you for sharing your detailed insights.:)
The Ferrum WANDLA looks and tests very well:
At the current price of $3200USD, I was hoping it had a built-in ESS ADC to fully round it out.
OT#1: Interesting to see that 'component designators' are not part of any of the 3 PCBs.
OT#2: Out of curiosity -:oops:- how many layers make up the main board?
I upload photo on imgur, is that a problem to access from UK?
Actually imgur banned TW user to login and upload
Imagur blocked in UK...
This is due to lack of age verification on Imagur. They were threatened with a fine and chose to discontinue the service instead...
Small tip for rew:
in modern 64bit versions of rew you no longer need to use software like FlexASIO or ASIO4All to get bit-exact routing with mixed device IO.
Simply set the driver to Java and then select the EXCL versions of your DAC and ADC in the drop-down device list.
It's more stable than the workarounds and handles device disconnects better.
You can upload images directly into your post here. Like this one:
Why doesn't the OP simply upload images to the forum - that's what it's there for?
They're blocking access from the UK after the Information Commissioner started investigating apparent non-compliance with UK laws around age checking and use of children's personal data. As with other geo-blocking, you can work around it using a VPN to appear to be somewhere else.
https://www.bbc.com/news/articles/c4gzxv5gy3qo
Code:
https://help.imgur.com/hc/en-us/articles/41592665292443-Imgur-access-in-the-United-Kingdom
Code tag because the editor recognises imgur URLs and turns it into a broken media tag and this is the only way I've found to stop it
- plain text because the editor recognises imgur in the url and turns it into a broken media tag instead of the link I entered.
I already posted that with the IMGUR link fixed in my post :) https://www.audiosciencereview.com/...rum-audio-wandla-teardown.66344/#post-2414774
I was looking for an endgame system, but w/ iem's according to reviewers there's a slight noise floor, but either way something beyond say whatever 1500 dollars I would imagine is ment for headphones at the least and speakers in mind if not primary. I'd put this up against the topping 900 stack, I'm willing to say it would give it a nice go.
