Fans in semi-enclosed AV unit?
Noctua fans are none of those: They are simply da-Bomb and they 'take a licking [w/o ever] keep ticking'!
:cool:
Right, after just checking out the name on the fans in his cabinet "Gaiatop", they don't appear to be quality, low noise fans
like Noctua. I've used Noctua fans for many years in my computer builds and gear cooling. IME They do live up to their claims.
I got the amp that I thought was overheating back from the tech. He said it wasn’t overheating, and to switch the L and R amps to see if it’s the speaker causing it. I did that and found that actually the amp IS hotter, but not as hot as I thought maybe. I measured the temp on the side of the case where the heat sink is and noticed the “hot” amp was running 5-7 degrees hotter at around 90F, while the corresponding amp on the other side was at 85 and the other two on the bottom were at 83.
I called the tech and he said it's nothing to worry about since it's not really that hot and the bias should be within range on both amps. Also he said the top amps will run hotter since they are powering the mids/highs which have a different impedance.
