I've got one of those hooked up to a Loxjie A40 amp right now. Playing music at a level slightly louder than normal, it shows it is using 7.6 watts.
Is the Amps metering fluctuating? if so what kind of delta?I've got one of those hooked up to a Loxjie A40 amp right now. Playing music at a level slightly louder than normal, it shows it is using 7.6 watts.
OK cool. What I am interested in with your providing the delta change is to see what the sample rate and resolution of a varying waveform is like when the meter gives us a readout. Interesting. Can you crank it a little to see how the delta responds then?Changing between .133 and .145. It stays on .133 for several seconds, changes to .145 for a couple of seconds and then back to .133.
Hmmmz. I suspect the digital metering software and circuitry in the metering device is not fast enough/resolving enough for a musical source. So sine waves will be required for a steady state voltage and current.Cranked it to volume level 30 (way too loud for comfort). Amps changed to a low of .177 and a high of .189. Watts changed to 8.4.
Of course it won't be... the power supply and its capacitors and stuff filter things both ways - It stops 50Hz of the mains from reaching your music, it also stops the fluctuations of our music from reading the mains. That's how your music continues playing when the AC is instantaneously at 0V.Hmmmz. I suspect the digital metering software and circuitry in the metering device is not fast enough/resolving enough for a musical source. So sine waves will be required for a steady state voltage and current.
Yes, I was drooling on that device too and formulating a system to get it on a workbench with the metering gear. The issues with it is it needs a project box, a AC main output outlet, a extension cord for mains power and a bunch of labor to get everything mounted in a project box. These links in post #1 where also attractive till I was recommended to look to the Kill-a-Watt meter.>>>Purchased this on Amazon in 2021...
Ohms
Yes, thanks for that techy info that I needed. The Watt meter also seems to update the display too slowly too.Of course it won't be... the power supply and its capacitors and stuff filter things both ways - It stops 50Hz of the mains from reaching your music, it also stops the fluctuations of our music from reading the mains. That's how your music continues playing when the AC is instantaneously at 0V.
In fact it is this filtering effect that makes the power factor an a$$ by making power flowing only during that 1ms capacitor recharging duration.
So basically for our needs one can run a 1 k Hz sine wave and set say an amps' power output to say 0.5W, 1W, 5W and maybe more to get repeatable reference numbers.It's only useful for power consumption on the supply side. For that purpose, it is excellent, accurate, cumulative and inexpensive.
To have graphical plots is the 100% best goal for sure although is that a lot of work or is it pretty simple once the spreadsheet is made and then the variables are entered into the fields?If you want to know how "efficient" your amplifier is, sure.
Set the amplifier to produce a specific output voltage (AC VRMS) across a known resistive load to produce a known power. Make that input continuous and then measure the input consumption in Watts/VA whatever. Do that for various (input levels)/outputs, ranging from idle through to rated/clipping power and drop all those numbers into a spreadsheet. Then plot consumed vs supplied power as an efficiency percentage.
In reality, you don't need many points. A bunch around idle to a few watts, then 2 or 3 up to and including clipping.
It's an exercise we all do at some stage, but it's not something you want to be doing every day.
Of course that would require the usual SINAD @ 5W to last for at least a few seconds to work, and I honestly have no idea how long that test is.
Most Kill-a-Watt wallplugs also measures power factor... which is telling.My very old "Kill-a-Watt" meter reads Volts, Amps & Watts. The new ones have more ranges.
As soon as a calibration NIST certificate is completed and the label is signed and adhered to a device the price goes up considerably.Well, as I said elsewhere today (on roughly the same topic), NIST-traceable calibration would be nice...
