DubbyMcDubs
- Joined
- Jul 2, 2019
- Messages
- 114
- Likes
- 103
JBL Professional - SCS8 - Spatially Cued Surround Loudspeakers (Pair)
$1,250 AUD (Pair)
Mint condition. I imported 8 of these speakers from the USA for my home theater. Two of these are for sale as they are not fit for purpose as side surrounds in my room, the outside seats are too close to the wall and will alternatively use bipoles in those locations. These are an amazing full range surround/atmos speaker that has a huge 120 deg radiation pattern with great off axis performance. Very hard to get hold of in Aus. If someone needs a second pair, I may consider selling another set and swap out my rear channels to something else. The atmos speakers however will not be sold.
Price includes brackets and orignal mounting hardware.
https://jblpro.com/products/scs-8
The SCS 8 is a coaxial-driver, 2-way, full-range cinema surround loudspeaker ideal for multi-channel surround formats and is designed for overhead installation as well as for standard on-wall installations
$1,250 AUD (Pair)
Spatially Cued Surround Loudspeaker 2-Way Coaxial with 8" LF
Features
- 250 Watt power handling (average continuous pink noise) with high sensitivity provides high SPL capability.
- Consistent 120° x 120° broadband pattern control
- Extraordinary clarity cinema surround with extended frequency response for special effects
- Components:
• 200 mm (8 in) woofer with Kevlar-reinforced cone and 50 mm (2 in)
voice coil.
• 25 mm (1 in) exit compression driver with unique patented design
and high temperature polymer diaphragm. - 70 Hz – 20 kHz frequency response
- High-power passive crossover network
- Overload protection
Specifications
Frequency Range (±3 dB) | 90 Hz – 20 kHz |
Frequency Range (-10dB) | 70 Hz – 20 kHz |
Coverage Pattern | 120° x 120° |
Directivity Factor (Q) | 8.1 (1 k – 16 kHz) |
Directivity Index (DI) | 8.4 dB (1 k – 16 kHz) |
Power Rating | 250 W 2 hrs.200 W 100 hrs |
Sensitivity | 94 dB (Ave. 90 Hz – 20 kHz) |
Maximum SPL (1m) | 118dB |
Crossover Network | 2.1 kHz, 3rd order (18 dB/oct) high-pass plus conjugate to HF, 2nd order low-pass to LF |
Nominal Impedance | 8Ω |
LF Driver | Kevlar-reinforced cone with weather treatment, 50 mm (2 in) voice coil. |
HF Driver | 25 mm (1 in) diaphragm and voice coil diameter, high temperature polymer diaphragm, patented design, fluidcooling. |
HF Driver Protection | Minimum audibility SonicGuard™ HF overload protection |
Enclosure | ABS with Glass enclosure, heavily braced |
Attachment | Two M10 points for included U-bracket. M6 secondary safety attachment point on back panel. |
Grille | Corrosion-resistant zinc-rich steel grille. |
Input Connection | CE-compliant covered barrier strip terminals. Barrier terminals accept up to 9 mm outside 4 mm inside openlug (#6, #8 or #10) plus bare wire up to 2.5 mm2 (12 AWG) wire or spade lugs. |
Dimensions | 300 x 300 x 305 mm (11.8 x 11.8 x 12.0 in), cabinet 359 mm (14.2 in) including bracket extending to back |
Colors | Black |
Net Weight (each) | 8.2 kg (18 lb), 10.0 kg (22.0 lb) with U-Bracket |
Shipping Weight | 11.4 kg (25.0 lb) |
Included Accessories | U-bracket, steel. |
Horizontal Coverage Angle (-6dB) | 120° |
Vertical Coverage Angle (-6dB) | 120° |
Power Handling (2Hr AES Rating) | 250 W |
