Extreme Snake Oil
It wouldn't surprise me if some snake oil producer latches onto the LOBO™ concept and starts making this BS for real!
Honestly it was poe's law for me, the biggest tells that is wasn't real were just that it was posted here not as a screenshot and the AI character had a missing tooth. Otherwise it's no crazier than a lot of stuff written "in earnest' about snake oil.
Hi kemmler3D,
It's funny you should say that as I wondered for some time whether or not to use the missing tooth, given that it was a bit of a giveaway (to say the least!) that the whole thing was a ruse.
I asked CoPilot to reposition it to the side to make it less obvious but ultimately I left it as it is. The fact that he could do with a new tooth but still managed to blow $50,000 on the LOBO™ cracked me up!
BTW, I've never heard of Poe's Law until now. I've just looked up its meaning and it's very similar to what I suspected. Nother to do with Edgar Allen Poe though. I certainly got that wrong!
Every day's a learning day! :D
It's prettier than the golden teapot.
Consider producing them. Maybe just with magnets to go on equipment. Make it the more the better and $1.5k a pop. :)
You could make a play that the aerials (antenna) trap stray EMI/EMF waves and sink them to ground via the metal casing.
Or better (given many cases are non-ferrous), that the bulb contains some nano/quantum unobtanium compound that does the dissipation. Device is attached via easy peel adhesive.
And obviously the more you festoon on your equipment the better the sound.
It would be an interesting sociology project to create a web site, have different offerings for different equipment types (say two aerials, larger bulbs, different metals etc), have an option to sign up for news and hint at an early adopter discount. Then set up some social media channels and see what uptake happens.
Peter
From a review of the Roon Nucleus One (a Roon server):
"Roon now offers two physical machines, the Nucleus Titan at £3,899 and the Nucleus One under review here at just £699.
Where the differences lie are in computational power between the two devices which has an impact on capacity. The Nucleus One can handle up to 10,000 albums, whereas the Titan targets folks with ultra-large libraries exceeding this." (emphasis mine)
Indexing may be slower if processing power is the bottleneck, but index size is not limited by the processor. And 10k albums/100k tracks are trivial to handle for anything even remotely modern. My early 00s mini laptop could handle that much easily (when indexing files for the filesharing client SoulSeek) with less than a quarter of the RAM my current phone has.
The 10k limit is simply product differentiation.
I have no words. Really. How delusional do you have to be to claim that your high-end all-in-one streamer/DAC/amp may get medical certification as a "healing device" so that doctor's can prescribe it to their patients - because you run your DAC 1.8% slower because that change in pitch means the music "communicates with every cell in your body"?
Here are excerpts from an interview with Sven Boenicke, of the eponymous audio company:
"[...] the so-called 432 Hz downpitching. This is an add-on module that goes on the DAC.
It lets us play back music as if it were recorded at a lower tuning pitch of 432 Hz, instead of 440. You can engage or disengage this special downpitched mode as you want. But I would say, once you have experienced what 432 does to you and your whole body when you listen to it, you will never switch it off again. [...]
We decided not to do it in software, but to actually clock the whole DAC slower. So we bought a custom clock, which was especially made for us. It clocks the DAC about 1.8 percent slower, so you get the correct pitch if the original material was recorded at 440, which is actually the standard pitch. So we play back the whole music a little bit slower, and therefore the musical piece gets a little longer. If you have a five-minute piece, it gets about five seconds longer. [...]
From a high-end standpoint, it sounds more like an analog reel-to-reel tape compared to a CD. It brings much more naturalness, more calmness. It’s more grounded; it seems to have much more stable bass and more organic highs. But what it really does is, it actually communicates with every cell in your body. So it’s actually, if you want to call it that, a healing device. As it stands, we might get medical certification for it so doctors can prescribe it as a healing device."
But wait, there's more: wood blocks on each driver magnet, engraved with some special information which improves the sound of the speakers (?). From the interview:
"[the inventor] has found a way, with the help of a laser, to engrave information into a carrier material, and that information apparently stays permanently in the information carrier material. And my ears tell me it totally works. [...]
this cannot be measured. Maybe one day, if the correct measurement device were built so that such a thing could be measured, who knows, maybe then it could be measured. But up to now, I think such a thing cannot be measured. They designed those information carriers actually for my products, but they are all the same for all the products and for all the drivers. So it works for all the drivers. [...]
For other brands, it could be different, because other people stand behind other brands. The way those carriers relate to who I am. So it’s designed for me personally, for my spirit, which is inside my products and is being transported."
My digital audio player added a "432 Hz pitch shifter" plugin with the last update. High time I try it! Maybe after listening to Mahler's "Resurrection" symphony that way I'll rise from my bed tomorrow without my PostCOVID brainfog and fatigue (which would be wonderful and feel like a miracle, but still obviously just be coincidence).
Oh, the master himself. Who brought us the magical speaker firewalls.
We better read that. :D
"And my ears tell me it totally works. No, this cannot be measured." :D
The speakers are not that uninteresting, although prices look a bit randomly high to me.
But he gives it all away with the wooden voodoo boxes like that ComDev. Simply an insult to intelligent life IMO.
I had a demo of the W5, I thought they were piss-poor. Nearly fell off my chair when I found out the price.
The focus seems to be a lot on material. That alone does not produce good sound.
Actually not installing crossovers (as he explained) sounds like a slippery slope to me.
One of the worst speakers I have ever heard, and there is plenty of competition!
That, aside from the very low value for money, was the problem. The mid-bass runs into breakup and adds roughness to the sound.
I knew nothing about the speakers before I had the demo, only heard the name. Only later discovered that he doesn't think he needs filter the mid/bass driver because 'phase'. If you read that full interview nothing he says about anything makes any sense.
Would certainly make my top ten. Reminded me of the Wharfedale Delta 30 which one of my brothers had and asked me to fix. Got inside them, no crossover just a cap on the tweeter. Ah so that's why they sound as rough as a badger's arse!
Easy fix, a push tag had come loose. Difference is they were Wharfedale's cheapest speaker at £50 a pair back in the 1990s whilst Boenicke wants the thick end of six grand.
Anybody who cared about getting best possible time domain performance would have used a DSP crossover.
