Extreme Snake Oil
I'm not sure what measurement threshold is being referred to [...]
There are two issues with the quoted passage:
- Actual achievable measuring thresholds are orders of magnitude below "a few hundred thousands of a second", so the statement is very wrong in absolute terms (high-res audio at 384 kHz sampling rate already measures down to that range!).
- In a experiment where the thresholds of audibility of timing differences are determined you obviously need to be able to determine the magnitude of these differences, i.e. be able to measure them, as part of the setup. How else would you be able to quantify the results?
As I said, logic is broken with the full-on audiophools. (I see no reason not to use that term. It is nicely descriptive and ASR should be a place to ridicule these people. The community here is also providing all the information they would need to abandon their religion should they ever pause to actually think critically.)
Introducing the LOBO™ Quantum Passive Signal Retrieval Device
After nearly a decade of research into quantum-scale interactions between passive metallic structures and the naturally occurring electromagnetic emissions of audio electronics, we are pleased to announce the LOBO™.
The LOBO™ Quantum Passive Signal Retrieval Device
represents a breakthrough in personal audio optimisation.
Unlike conventional accessories, LOBO™ requires no electrical connection to the audio chain, consumes no power, contains no batteries and requires no charging.
Instead, each precision-machined receiver utilises a proprietary Quantum Passive Coupling™ architecture to capture previously undetectable informational artefacts emitted continuously by DACs, amplifiers, streamers, power supplies and other critical electronic components.
These artefacts exist beneath the conventional noise floor and have historically remained inaccessible to measurement systems. Yet extensive listening trials suggest they contain valuable musical information.
What Does LOBO™ Do?
Conventional audio equipment reproduces only the intentionally transmitted signal. LOBO™ allows the listener to access secondary quantum-adjacent informational structures that are naturally radiated by the component itself.
These emissions have existed all along. Until now, nobody was listening.
Key Features
✓ Proprietary Quantum Passive Signal Retrieval™
✓ Precision-Matched Stereo Pair
✓ Surgical-Grade Stainless Steel Construction
✓ Passive Operation Compatible With All Audio Systems
✓ No Batteries
✓ No Charging
✓ No Firmware
✓ No Electrical Connection
✓ Lifetime Performance Stability
✓ Resistant To Scientific Scrutiny
Reported Benefits
Beta listeners consistently reported:
• Improved micro-detail retrieval
• Enhanced timing precision
• Increased spatial coherence
• Superior instrument separation
• Expanded soundstage dimensions
• More convincing decay characteristics
• Improved perception of venue ambience
• Greater emotional engagement
Many listeners described hearing familiar recordings as if for the first time.
The LOBO Principle™
Traditional audio engineering focuses exclusively on measurable phenomena. LOBO™ begins where measurement ends.
Each stainless steel retrieval module is individually resonance-calibrated and supplied as a matched stereo pair.
When positioned on the earlobes and secured using the supplied neodymium discs, LOBO™ establishes an optimised quantum retrieval field centred around the listener's auditory processing pathway. This allows naturally occurring micro-signals emitted by nearby electronic equipment to become perceptually available. Not because LOBO™ changes the sound. Because LOBO™ changes access.
Technical Specifications
• Operating Principle: Quantum Passive Coupling™
• Power Consumption: 0 W
• Signal Connection: None
• Frequency Response: Not Applicable
• Firmware Updates: Not Required
• System Compatibility: Universal
• Calibration: Hand Matched
• Quantum Retrieval Factor: Proprietary
• Measured Performance: Beyond Current Instrumentation
• Listening Performance: Exceptional
• Scientific Acceptance: Pending
• Capacitor Empathy Resolution: Unlimited
• Quantum Transparency: Reference Grade
• Soundstage Inflation: User Dependent
• Emotional Harmonic Recovery: >99.999%
Customer Feedback
"Within seconds I noticed substantially improved image density and harmonic texture."
"I could hear the recording engineer shifting position during a 1963 jazz session."
"By the third album I became aware of the emotional intention of the power supply capacitors."
"The silence between notes became significantly more musical."
"My wife couldn't hear the difference, but she was standing outside the primary quantum retrieval field."
Sebastian Neptune - Retired Enthusiast
Scientific Statement
While independent laboratories have thus far been unable to measure any objective performance enhancement attributable to LOBO™, our research team attributes this to the continuing limitations of contemporary scientific frameworks.
The history of science teaches us that absence of evidence should not be confused with absence of performance.
Pricing
USD $50,000 Per Precision-Matched Stereo Pair.
Please note
The LOBO™ website is currently under construction.
Another banger review from alpha-audio.net: an audiophile residual current breaker
The guy installed it himself (!). The thing is apparently in series with a non-woo breaker and magically improves <all the usual audiphile woo subjective improvements>. His control for avoiding bias: disconnecting the thing and doing more sighted listening! He considers the 500 EUR for this at-best-completely-useless device to be "among the most efficient" he has spent on his system.
BTW: I was a bit snarky in their comment section for their last amplifier review and after receiving a first-and-final warning which I didn't respond to my account I created for that seems to have been deleted. My question was how the reviewer was able to determine the contribution of the reviewed amplifier to a system which included speakers which he didn't know. The answer was "It would be weird if I couldn't with my decades of experience."
As a simple [minded] biochemist, I always get confused as to how woo works from the perspective of Ohm's Law.
Is woo in series additive, or is it that 1/(1/woo1 + 1/woo2 +...) thing?
:cool:
PS I trust that the woo of the Home Depot-grade breaker is unity and not zero. Otherwise, we might get into... you know... complex woo spaces and stuff like that. :eek:
:cool:
It convolves like signal transfer functions, so F(Money)*G(Money).
Hornby R658 OO Gauge Inclined Piers​
Any audiophile with the vision, wisdom, and 'golden ears' necessary to appreciate the magic of cable lifters will surely welcome this accidental hi-fi accessory from Hornby.
After several months of intense analysis, I have determined that when arranged (by sheer coincidence) as displayed below, these inclined piers are able counteract a remarkable phenomenon affecting any type of hi-fi cable.
As the only person on Earth capable of researching and quantifying this phenomenon and the effect that these inclined piers have on it, I have attempted to distill the essence of my research for the layperson using the following simple terminology:
Specifically, the Hornby R658 OO Gauge Inclined Piers are able to completely negate the effects of spacial and temporal dimensional dissolution of electrostatic vibrations caused by collapsing wave functions propagating non-linearly towards planar surfaces.
Those of you wishing to purchase a signed, limited edition set of Hornby R658 OO Gauge Inclined Piers may do so for a very reasonable USD $2,000.
Enquiries by private message please.
What Does LOBO™ Do?
Key Features
✓ No Batteries
✓ No Charging
✓ No Firmware
Reported Benefits
The LOBO Principle™
When positioned on the earlobes and secured using the supplied neodymium magnetic discs, LOBO™ establishes an optimised quantum retrieval field centred around the listener's auditory processing pathway. This allows naturally occurring micro-signals emitted by nearby electronic equipment to become perceptually available. Not because LOBO™ changes the sound. Because LOBO™ changes access.
Customer Feedback
Pricing
Please note
Variants are coming soon - The Rio Lobo and the Sheriff Lobo.
it's good to keep in mind that a lot of the people who read those forums might be sensible.
Indeed, when I was on my crusade to push back on the crazy network stuff, I wasn't alone in trying to show the fallacy of the true believers thinking.
BUT... we were very much in the minority.
The counter point would be that maybe there are lots of rational people that browse audio web sites but never post/have a logon or if they have a logon don't want to waste energy on trying to make people see sense.
I have thankfully joined that later group and just treat all the nonsense as white noise.
Thus it really is impossible to determine across all audiophiles what percentage are audiophools. All we see are the most radical audiophools starting posts about their latest quantum jock strap causing veils to lift, blacker blacks etc.
Peter
I am currently developing a variant for the totally insane - the LOBO-TOMY™.
I have had a significant number of enquiries from subscribers to Stereophile and The Absolute Sound.
(No offence intended!)
This makes total sense as removing unneeded brain activity that can distract the listener allows them to hear more deeply into the music mix.
Thus by removing all brain tissue not related to hearing, all extraneous and distracting thoughts are eliminated.
Pure Genius!!!
And it won't affect the critical thinking skills of the Stereophile and The Absolute Sound subscribers as they didn't have that to start with!!!!.
Peter
That's not fair. I have subscribed to Stereophile for decades not because i agree with the content. I actually don't think it is a good audio magazine at all and don't agree with much of it's content. but it is so cheep. I give it a quick look/read over and off to the trash it goes. If you only expose yourself to that which you agree you sacrifice your ability to make judgements about that which you disagree. At any rate I believe there are a substantial number of subscribers to Stereophile that are not of their mindset. Like I said, it is just so cheep it's worth a quick peek just to see what those crazy's are up to. Besides i am old enough to still enjoy reading magazines. I use to really enjoy getting my copies of Recording Engineer Producer and Mix magazines every month. I wish there was a legit science based audio magazine around that focused on high quality stereo music reproduction. I would subscribe to that in a heart beat I realize that you may have been 1/2 joking in your comment. Have a nice day.
Hi there.
Very reasonable points mentioned and I strongly suspect fatoldgit didn't mean to cause any offence, nor did I with the comment he replied to regarding my fictional LOBO-TOMY™ product, which I did end with "no offence intended!"
I once regularly frequented Stereophile and Michael Fremer's spinoff Analog Planet, and I have to say that I generally enjoyed my time on them.
However, that was then and ASR is now, so it's hard to look back with anything like the same degree of enthusiasm given what I have learned since, both about hi-fi products and the industry as a whole, including it's many totally corrupt snake oil producers!
I too subscribed to Stereophile back in the day when JA1 was editor (will the real JA please stand up, please stand up). And the attraction was obviously his measurements.
Since Stereophile eventually trickles it's reviews out to their website, no need to subscribe now but I see offers for basically a buck a month so if I was interested then it's essentially free.
Now The Absolute Sound is a different animal.. All "vibe" reviewing of mega buck gear with no basis in fact. And lets not forget Rob Harley and his crusade to push MQA starting 2015 and continuing on for several years. I made the comment in another thread that Bob Stuart (of Meridian) must have had "pee" tapes on Rob Harley given how hard Harley pushed MQA.
Fundamentally, the web changed our relationship with audio gear purchasing, noting I can't stand youtube reviews... give me text.
The biggest effect of the web was the rise of audio forums where you can get real life commentary on gear (once you filter out the "woo woo" posts), heads up on new gear etc. The old guard magazines had the market cornered on reviews/news but the web blow that open.
I peruse the websites for steve hoffman, pink fish, stereophile, mono and stereo, 6 moons, audiophile style and others daily, just to see what crazy shit the subjectives are up to and then hit ASR to clear my mind.
ASR is a place where 100% like minded, objective people co-exist in relative harmony (and what fights we have involve handbags so no lasting damage done) and is unique in that respect (not the handbags.. the objective people!!)
And of course, my comment was tongue in cheek. I am a very sarcastic old bugger and that twinkle in my eye that you would see in a face to face setting (to show you I was kidding) gets lost in text. Oh how I suffer and how mis-understood I am.
Peter
PS. I appreciate that we can use "naughty" words like shit on ASR, we are treated like adults... all the others asterisk out "naughty" words
So Stereophile's Recommended Components is out and it makes riveting reading.
The highlight for me was the CH Precision C10 Reference DAC for a mere $105,000.
But wait... there is more.
For $6000 you can add an Ethernet input and a USB input for $3000.
I will have to check out the measurements just to see what the performance for the money ratio is.
Peter
It's prettier than the golden teapot.
Consider producing them. Maybe just with magnets to go on equipment. Make it the more the better and $1.5k a pop. :)
It wouldn't surprise me if some snake oil producer latches onto the LOBO™ concept and starts making this BS for real!
Quantum is a good topic. Nobody knows exactly what it will entail in his personal life to come, so it's good to LISTEN now.
Chat, spawn a little webshop and buy 10 $audiofool reviews. Target: a smooth 75 mln :D
