Nutul
At least he didn't say "olfactory situation"...If I ever catch you going OT using those 2 words again, I shall have to report you to our enforcement bureau!
Wow! That list is truly insane. Even if I had money to burn I'd never go that crazy.A list of the most expensive speakers.
I assure you, the vast majority of them are snakeoil.
Edit: I think this website is blocked by ASR. It's on that headphone honest website.
You go too far. Many here have all the credentials you do, and more besides.I urge you to go listen to real music.
I've been following, and lurking, on ASR a bit longer than you. I also have a background in electronic test equipment and (analog, digital and RF) equipment, and music, etc...
ASR is well known in many forums.. there have been tons of discussions over the years. Some, I've had in person, some on forums, observations.
Do not conflate measurements with a set of instruments as being able to reproduce the real thing. It is outside the scope of ASR. Just because an amplifier measures correctly, doesn't mean it can realistically reproduce a performance.
Let me ask you something else... have you ever done any recording? I did, back in my youth, from '79 to 84.
Sigh.
Veils aren't dropped; they're lifted.You go too far. Many here have all the credentials you do, and more besides.
Before you can claim a recording sounds live it has to have been mixed and mastered with that objective. It almost never is. But many want to take a recording that was mixed and mastered for, say, clarity, and turn it into a live performance in a hall with a 5-second RTA-60 like their favorite cathedral. The philosophy of playback for most here is not to make a common recording something it wasn’t even intended to be, but rather to present it as exactly how it was intended as possible.
That may not be the best outcome for some recordings, but it demands better evidence than assertion that making it better is something, say, a pricier amplifier (or whatever) can do.
The audiophile commentariat rarely makes the claim that it sounds more like live performance, of course. That’s so 1965 (when such comparisons—conducted blind—were like the Coke-vs.-Pepsi taste tests in terms of advertising). No, the judgements typically include:
-blacker background
-makes me want to listen more
-dropped veils
-wife heard the difference from the kitchen (where audiophile wives are apparently doomed to reside)
-life-changing difference (compared to last week’s SOTA, which was also life-changing)
-finally hear the truth in the music
-PRAT
I find that just about any reasonable recording sounds like live music when played at live listening levels. I play tuba, so I’m used to sitting in the ensemble as much as in front of it. One of my use cases is playing along with recordings. Tubas are loud, and I don’t want to have to hold back, and that requires sustained output in excess of 100 dB without any obvious breakup or distortion.
But it also means the dynamics of the recording need to be similar to actual performance, and that is too rarely the case. Pre-digital recording equipment could do it, for one thing. And too few listening environments allow the dynamic range of a good concert hall—recordings need to work in, for example, cars in addition to an optimized listening space. Usually, when the brass is loud enough in the fortissimo orchestral tutti, the solo English horn solo in the next movement will be way too loud, at least from my seat, because the dynamics have been compressed.
With rock music, mostly it’s just a matter of being loud enough without clicks (caused by clipping) overlaying the kick bass drum on 110+ dB peaks.
I have played equipment that compresses dynamics because it runs out of steam, and loses realism as a result. My current system does not do that. It comprises a CD player, a Holman preamp (but I had the same sense from several other preamps—a B&K Sonata MC-201, a Kenwood C1, an Adcom GFP-565, and others), an NC502MP stereo amp (330 wpc into my speakers), an unbalanced-balanced amp, a Yamaha commercial digital parametric equalizer, and Revel F12 towers. All of that adds up to less than $2500 on the used market. It sounds real because it can make reference loudness without distortion.
The only problem is that live sound levels for rock music are intolerable in my listening space, as would be the actual band set up and performing there. My ears distort at lower levels, for one thing. You limit peaks to 95 dB, but I think that precludes a live-sound experience with music that is performed amplified. But it sounds great from the kitchen
But I’ve heard a real brass quintet in my listening space any number of times, and good recordings of brass quintets, when played similarly loud, sound completely real in comparison.
Rick “real power that was clean used to be real expensive” Denney
Dang, I forgot.Veils aren't dropped; they're lifted.
Dang, I forgot.
Rick “Mea culpa” Denney
"Premium Audio Placebo"... love it
Also available: Audiophile earplugs -- artisanally crafted and painstakingly curated for use with Klipsch loudspeakers.
What happens to vials there?ΨRick, you were thinking of veils in the Southern Hemisphere.
-blacker background
-dropped veils
-PRAT
But it also means the dynamics of the recording need to be similar to actual performance, and that is too rarely the case. Pre-digital recording equipment could not do it, for one thing. And too few listening environments allow the dynamic range of a good concert hall—recordings need to work in, for example, cars in addition to an optimized listening space. Usually, when the brass is loud enough in the fortissimo orchestral tutti, the solo English horn solo in the next movement will be way too loud, at least from my seat, because the dynamics have been compressed.
integrity can be bought. If someone asks me to say that I hear an improvement when switching from this network router to that (more expensive) network router, no way. But if they pay $1000, maybe. $10k, absolutely. If they pay $100k, I will advocate for life!I cannot believe such words from an engineering guy
Some people are idiots; some, gullible, some, too afraid to miss out; and some, easily or expensively bought. A very few seem to have good old-fashioned integrity.I cannot believe such words from an engineering guy
