Something was dense for sure but it wasn't the sound, it was the tester"slightly diffuse density."
Ok, I have for a few years now had Shunyata as the "King" of the snake oil sellers. They represent the worst of the worst. They have it all. Marketing material that is pure rubbish and techno nonsense by the bucket full. I always wish someone with deep pockets could sue them out of existence. Then I foolishly looked at some Audio rags, I mean mags yesterday and saw an ad for Synergistic Speaker Wire I think it was. $28,000 for an 8 foot length. I now have put them at the top tier with Shunyata as both companies need to be hounded out of business. They represent the worst of the audio world. I know I should not be surprised, but I still am at the overwhelming amount of rip off and scam artists that are dominant in the audio industry. Just thought I would mention it today.
Our "hobby" is dominated by low life's, criminals and scammers of the highest order. They are true professionals at their trade.
Perhaps the research they are referring to is marketing researchBeware of any audio companies with "Research" in their name. While I believe both are 100% snake oil, Synergistic is just over the top. Audiophile fuses, ... it's kind of hysterical.
It’s not a real ground anyway ,sometimes it’s literally a box of dirt like entreq ( they are covered back in this tread ), no actual grounding of any electrical circuits.I happened to be passing a stereo equipment store I knew nothing about and decided to stop in for a look-see. I mentioned that I was both a computer geek and interested in high-end audio. The man tried to sell me on a music server ($6500), a special ethernet switch (@2500), some expensive ethernet cables ($1000 each) and something he called a ground block: the Synergistic Research Galileo SX Active Ground Block Mk II -- said it would make the world of difference in the sound of my system.
For $12,500 for a "ground block" it ought to wine and dine me for years. I think the one in the server room at a very large law firm where I once worked cost about $200. For home use, a ground block is seldom needed; however, if you really want one, it should be under $30.
Needless to say, I won't be shopping there in the near future, or, like EVER!!!
Shhh. Don't tell. You may cause some audiophile to feel discriminated and/or offended.Note that all Safety Ground/Protective Earth wires are connected to the Neutral in the main breaker box (it's good to have a different paths to that Neutral for all things not hi-fi). The homes Neutral is then connected to that big power company's transformers Neutral down the street.
While there is continuity from the Neutral to Planet Earth:
The Planet Earth connection has little to do with day-to-day AC power quality (and it has lots of inductance).
Low impedance not zero , ive done ground impedance measurements myself when working at a power company , but anyhow it's bollocks
The ground comes via an actual cable to your house not zero impedance . I agree that it is a point of common coupling . Gnd ( like L & N ) is then distributed to each outlet it can actually in practice be pulled from outlet to outlet in a daisy chain not every outlet has it's own separate wires straight to your fuse box.
Hence why it can be good to connect everything to the same outlet , every device get the same GND potential .
Entreq's bizarre boxes are just free floatingmaybe they do weird stuff in radar frequencies ?
The Empire Plus - Furutech
furutech.com
Could be the pinnacle of the snake oil, because it is targeted to "audio professionals"
That's actually a myth - at least if we take it to mean the least resistance path is the ONLY path it will follow. Current follows ALL paths, in proportion to their resistance. If the least resistance path is much lower than the others, a high proportion of the current will indeed follow it - but it's not all or nothing.Current, when figuring which path to follow, will ALWAYS follow the path of least resistance.
You got your own ground rod , it’s different around the world . Here its a ground wire system. There are rods somewhere but not adjacent to my house probably closer to the transformer, then its grid of uninsulated ground wires trough the whole neighbourhood to the distribution panels and then it arrives to my home in a four wire system 3 phases and PEN and then it splits in breaker panel to 3 phases N and PE .The impedance to ground is low, much lower than the backwards impedance seen from the other devices in common to that ground point. So, for purposes of shunting stray voltages to ground, it is negligible.
Individual installations of the grounding post will vary, but they will be magnitudes less "forward" impedance than the output impedance of the devices up stream (backwards). In my residential installation, the ground anode is five feet away from the breaker panel and it's a big rod and cable. The panel(s) are also fairly new... they got replaced 25 years ago and I keep them maintained and clean.
BTW, I've done work on RF.... Entreq is dubious at best.
Oh, absolutely, yes - I'm just being pedantic for the sake of those who might take the "lowest resistance path" thing literallySure, sure, current will flow in all paths... but, there is a practical limit.
You got your own ground rod ,...
Entreq more than dubiousit’s comedy . I’m fascinated by the product category , purely invented to con audiophiles out of money.
Sometimes audiophiles snake oil are distorted versions of real products like overhyped and overpriced cables .
But this kind of stuff ? You are supposed to need this extra box .
Sometimes I wish consumer protection laws where better
