Extreme Snake Oil
Imagine using green energy …
Hydrogen is on a 'a la carte' menu... from good-to-bad clean-to-dirty spectrum.
Has anyone researched the negative effects of massively increased humidity in cities if everyone was driving hydrogen vehicles? High humidity is not pleasant when it is hot outside.
Hydrogen vehicles might need to be equipped with dehumidifiers instead of catalytic converters.
Literally sprinkled with fairy dust.
Reviews on this page are incredible.
layered texture to the piano longer decay of the shimmer on cymbals
the sound stage became larger, the voices and instruments have more body with a black background
everything started to bloom open and sound three dimensional with deep and larger soundstage
All you need to experience all of the above is a fuse filled with bees wax. BEESWAX! INSIDE A MAGIC FUSE! (presumably to produce nice smell when your amp explodes and sets house on fire)
EDIT (I should've search the forum before posting but Im overwhelmed after reading reviews on "highend-electronics dot com"): beeswax-shd-fuse
Gasoline / diesel powered vehicles emit water vapor too. I would hope someone has done the research to determine the relative amount of water vapor per mile of gas/diesel versus hydrogen?
The stoichiometry of combustion, and the energy per H-H (and -C-H) oxidation are all pretty well established. :)
this trinnov db25 cable should be in the trinnov hall of shame $4.8k for a common db25 connectors and cheap cable , these leads only cost £60 or less
MOD EDIT: this cable is NOT produced by Trinnov but a third party.
Bog standard tin rubbish. But cudos for the price tag!
Which are just condensers, right...? Then, the hot sun of flat California would just bring that liquid water into vapor again... ;-)
But you could probably use the dehumidifier to cool the air inside the car....
Let's continue to progress away from tedious, humdrum, expensive cables, and the like and continue our journey with more exotic revelations...
How about this: Holostage
Small boxes containing secret, proprietary* materials improve the sound without a power source, nor any physical connection to anything; just by being in proximity to the listener, as it were.
No-one (at least none I can find online) has opened one of these boxes (don't blame them at $1000 asking price!), so the contents of these quasi-magical boxes still remain a mystery...
*not included even in the period table of elements?
