You didn't answer my questions...As long as the connection and shielding is of a good connection there will be no intermittent connection that may interrupt the digital data transmission. Even if there where some slight distortion induced due to a poor connection there are safeguards in the data transmission technology that prevent this from being heard and it can only be noticed by it either working or not working. There is no in the middle distortion zone; only ON or OFF. This operational mode where the signal is not working is called the indecisive zone. I post a couple of pdf pages from a Digital Fundamentals textbook of about 953 pages and this information is from Introduction pages. So this is basic digital transmission understanding and then from there it gets pretty technical. The images detail the zone where a distorted data transmission square wave are not perfect square waves because they are not and in fact some are pretty rounded off and distorted but the system still works because the technology has safeguards designed into it to prevent distortion and quality of cable from affecting the data transmission. So... If you could please read this I hope that you can understand that cable quality, increased data cable rate specification that exceeds the required amount are not factors in sound quality of digital data transmission.
So you're now claiming that there isn't a difference in the USB-C cables? That they are all the same?
Hmmm?
Did you also read the issue about the amount of power too?
Do you think that it would have an impact on the sound?
(It does.)
So c'mon... tell me that all USB-C cables will sound the same. Regardless of quality.
