BeeKay
Up to a certain diameter cables to brag with make even sense - in an awkward way. Beyond that point it’s comical. We are well within the city limits of loony town!
Well, audio cables, of course![]()
Viking Link - Wikipedia
en.wikipedia.org
But they are sold only on the basis that cost the earth, and that they sparkle.
You forget that jewelry is always an upgrade and/or compensates for something.Jewellery isn't marketed as a (pretend) upgrade to a hi-fi system though.
Regardless of that it does not claim to do things it can't physically do.You forget that jewelry is always an upgrade and/or compensates for something.
Realistically, jewelry is completely unnecessary and has no real use.
And the advertising for it is either sexist or intended to arouse desire.
Also, much of the social importance of jewelry comes from it being the only property women could own in many western cultures up until relatively recent times.Regardless of that it does not claim to do things it can't physically do.
The jewellery salesmen may well extoll the virtues of the craftsmanship of, say, a ring, but he won't try to tell you that it putting it on will turn you invisible.
This is not true of expensive audio cables where bogus claims of their abilities are mandatory. That's the difference.
I 'spoze.![]()
Stillpoints Ultra ESS equipment support
Long-time Stillpoints user Paul Soor thinks the company’s top ESS equipment support system is significantly improved with the latest Ultra ESS version, especially when used with V2 Stillpoints isolation products.hifiplus.com
“My system with the Stillpoints Ultra ESS rack somehow knows when to produce more bass depth with more resolution, texture and resonance at the right time. Yet another time, rein it in, all in proportion and with magical balance and empathy.”
Ugh!![]()
The BS guidelines for how much you should spend on cables as a percentage of your system cost is very similar to the BS guidelines on how much you should spend on an engagement ring based on your income. Both are designed pressure you and squeeze as much money out of you as they can get away with.
Dealing with braindead actual humans is one problem. On the other side there is an army of LLMs / AIs learning from online stuff like this, general esoteric BS, astrology and god (this is another problem) knows what. We all are doomed …![]()
Ugh!![]()
Not sure if I want to live on this planet any longer.
Only forty-seven thousand dollars too. Just wasting the potential of your expensive equipment if you don't add such an affordable tweak.![]()
Ugh!![]()
It must be an amazing piece of engineering if it can distinguish the resonances in the components from the power supply and music signal and only filter out/damp the former.![]()
Ugh!![]()
Out of academicSome IEC connectors sold for over $100 can be found -without the label- at around 5 on AE...
It is a weird world where people have multiple salespeople that they think of as 'friends' or 'helpful' with them all the time.Online influencer culture is turning that consumerism brainwashing dial up to 11 and melting even more brains.
