Extreme Snake Oil
a $3100 AC outlet that changes the way you listen to music...
It "will improve resolution, soundstage, and overall tonal/timbre balance in your system..."
Break In​
The higher the performance QSA receptacle, the longer the break in time. The Gold is no different, and being the top tier receptacle will require up to 60 days of break in time.
Q:I already have (insert brand name here) power conditioner. How will a wall receptacle improve the sound if the AC has to run through the power conditioner before getting to the components?
Q: Should I get rid of my power conditioner then?
A:
All I can say is it does. It makes a system wide, huge difference. Even though the AC coming from the wall receptacle has to flow through all of the filtering of the power conditioner. Whatever the QSA receptacles are doing to eliminate noise, your power conditioner is not filtering the same noise, and it will not hinder the performance of the QSA receptacle. Your power conditioner and the QSA receptacle are working on two different levels, and types of noise. I guarantee you will hear a difference.
A:Maybe, but probably not. As I said, power conditioners provide RF filtering, and other benefits. The QSA receptacles seem to work on different types of noise. All I know is that there is a significant improvement in the sound, even if you keep your power conditioner.
On another forum I’m on someone has raved about these isolation devices, each to their own and all that jazz but the marketing copy for them along with the cost gets my spidey senses tingling
My listening started with the Apex50 under a Moor Amps Angel 6 power amplifier, a 29 kilo beast that normally sits on four hard rubber feet atop an equipment rack that has damped spring suspension and thus is quite well isolated from energy travelling through the floor. Here three Apex50s managed to open up the soundstage and add definition to the image, it became apparent that this was achieved by lowering the perceived noise floor because quieter sounds were easier to hear. These feet allow the amplifier to produce greater purity of tone too, notes seem to be cleaner and there is more space between musicians. They did wonders for Michael Franks’ Art of Tea album on vinyl which had more groove, space, definition and solidity of treble.
Placing three Quiescent Apex60 Couplers under Tom Evans’ Linear A valve power amplifier had a different effect to that found with the Moor Amps, here there was a significant increase in image focus brought about by greater clarity and definition in the sound, the amplifier became more articulate, better able to reveal precisely what was going on in the mix. The change was not subtle at all and elevated this already remarkable amplifier another step or two up the high fidelity ladder.
Apex50 £1,250/ set of 3
Apex60 £1,950/ set of 3
Fool me once, shame on you...
Improved tonal balance? So this will work even if your system is schreehy and brigth or dull and uninvolved :) actually improve from any situation, ha ha .
"Turn a Quiescent Apex of any size over and it appears to be a shell that’s filled with some kind of resin, it’s not clear what goes on within this internal highly damped part of the block but Quiescent describe it as a honeycomb structure and this combined with the shapes on the surface is said to provide an irregular path for dissipating vibration. "
These items are nothing more than 3D printed plastic shapes. The internal "honeycomb" is the "infill" component of the print. In general, no 3D print is solid but has a solid shell with a semi hollow centre.
So basically, the maker has generated these items with no bottom layer and then filled the honeycomb infill with resin. The only additional component is the metal spike. All up these would run about $10 to make at the absolute outside.
I’m not going to mention that to him in the thread, I’ll get a warning…….again :rolleyes:
You received a warning from a moderator for pointing out complete foo, but not here?
on a certain forum (that shall be not mentioned) that you got banned from ;)
That doesn’t narrow it down.
...and it appears to be a shell that’s filled with some kind of resin, it’s not clear what goes on within this internal highly damped part of the block...
oh, my mistake! I thought I was on the UFO thread, reading a transcript of some Congressional testimony.
:cool:
:facepalm:
EDIT:
oh.
PS on my initial, quick glance at the photograph, I thought I was seeing small flames emanating from these gizmos! Now that would be innovative (if perhaps a little hard to square with global CO2 emissions accords ;))
but,
Warranty: 20 years, so there's that i guess!, not bad for a product without any electronics and does absolutely nothing!:D
