If a YouTuber asks you to jump off a bridge, do you oblige as well?The youtuber asked me whether I hear the difference.
I found the video is informative.If a YouTuber asks you to jump off a bridge, do you oblige as well?
How? You can't even compare the clips because not the same parts are playing... Not to mention the fact that you're listening to a recording of audio playback through speakers over YouTube, with probably at least two times re-compression... If there were any actual differences, they would be easily measurable if they survive that much degradation.I found the video is informative.
An emoji.. So we are sure? You know...Some important considerations when introducing cable lifters may include the impact of cable droop between lifters AND the problem of non symmetrical signal leakage at the point of contact between cable and lifter. A cable tensioner can alleviate the impact of cable droop. Custom lead foam insulators may address the contact leakage problem.
Yes, those 3 snake oils degraded sound. Between them, there’s still differenceHow? You can't even compare the clips because not the same parts are playing... Not to mention the fact that you're listening to a recording of audio playback through speakers over YouTube, with probably at least two times re-compression... If there were any actual differences, they would be easily measurable if they survive that much degradation.
I should have stated that a cable tensioner May alleviate the impact of cable droop instead of Can alleviate…. When I posted I was befuddled by the long thread dealing with veneer matching and fine woodworking in the context of the MoFi concentric loudspeaker.An emoji.. So we are sure? You know...
Peace
book-matched veneered tinker-toys for cable-droop fixtures...I should have stated that a cable tensioner May alleviate the impact of cable droop instead of Can alleviate…. When I posted I was befuddled by the long thread dealing with veneer matching and fine woodworking in the context of the MoFi concentric loudspeaker.
Both.Is this a joke? Or real?
Well, if I can get rid of the chalky midrange on my music, I'll be pleased. It aggravates me no end...Is this a joke? Or real?
2023 Editors' Choice: Best Digital Interconnects $1,000 and Above
2023 Editors' Choice: Best Digital Interconnects $1,000 and Above - The 2023 edition of TAS’ Editors’ Choice Awards is here. Our top equipment recommendations from loudspeakers, DAC's, amplifiers, and more. These are components that we ourselves would buy—or recommend to friends and family. Each...www.theabsolutesound.com
Torben
but this one is fast and smooth. I think I could live with some chalkiness if I had fast and smooth:Well, if I can get rid of the chalky midrange on my music, I'll be pleased. It aggravates me no end...![]()
Could be a good thesis defense statement.Chalky midrange is a pretty serious problem. There are several potential solutions: standard chalkboard eraser wiped gently across the midrange unit followed by the purchase of a silk midrange drape placed over the midrange unit. The silk drapes are available from any high end dealer and frequently are sold with an ionization package. A “magic eraser” treated with a small spray of contact cleaner is a more costly solution and may yield a marginally better result. At the top end of the solution family are custom midrange “rings” similar to those sold to stabilize CDs. If your chalky midrange is evident in a two way or planar system, there is probably no solution.
DO NOT use a standard eraser, this can lead to a swipy or cloudy midrange. Use Audioqvest’s Clarity(tm) midrange eraser for a crystal clear midrange. $800, or $2000 with our Chalk Eliminator(tm) cleaner.Chalky midrange is a pretty serious problem. There are several potential solutions: standard chalkboard eraser wiped gently across the midrange unit followed by the purchase of a silk midrange drape placed over the midrange unit. The silk drapes are available from any high end dealer and frequently are sold with an ionization package. A “magic eraser” treated with a small spray of contact cleaner is a more costly solution and may yield a marginally better result. At the top end of the solution family are custom midrange “rings” similar to those sold to stabilize CDs. If your chalky midrange is evident in a two way or planar system, there is probably no solution.
"silk drapes" !!?!?!?!?! Are you advocating the addition of veils? I thought the whole purpose of HiFi jewellery was to remove them!Chalky midrange is a pretty serious problem. There are several potential solutions: standard chalkboard eraser wiped gently across the midrange unit followed by the purchase of a silk midrange drape placed over the midrange unit. The silk drapes are available from any high end dealer and frequently are sold with an ionization package. A “magic eraser” treated with a small spray of contact cleaner is a more costly solution and may yield a marginally better result. At the top end of the solution family are custom midrange “rings” similar to those sold to stabilize CDs. If your chalky midrange is evident in a two way or planar system, there is probably no solution.
some are best left on"silk drapes" !!?!?!?!?! Are you advocating the addition of veils? I thought the whole purpose of HiFi jewellery was to remove them!
