Jean.Francois
- Joined
- May 31, 2022
- Messages
- 284
- Likes
- 1,055
Hello,
today, I’m taking you to the temple of vinyl record listening with François Saint-Gérant of Ana Mighty Sound. François offers a range of high-end and ultra-high-end turntables, as well as all the equipment needed to fully exploit their capabilities, including cartridges, preamps, and reproduction systems, amplifiers, and speakers.
So I propose a different experience: rather than simply commenting on the listening experience, I will share with you recordings in DXD 24 bits 384 kHz made in various dream configurations, in order to give you as accurate an idea as possible of the exceptional performance of this equipment.
But when it comes to getting the most out of high-end equipment, you can go much further in terms of precision and finesse of adjustment. This is where the AnalogMagik V2 test disc and, above all, the software provided come in, allowing you to make extremely precise adjustments using dedicated measurements.
Once these adjustments have been made, we obtain the following result: a difference of only 0.08 dB between the two channels in crosstalk, and distortion reduced to just over 3.2%.
Here are the four configurations that were tested:
The first turntable and phono stage configuration consists of:
The second turntable and phono stage configuration consists of:
Finally, the listening session at Ana Mighty Sound was carried out on the following system:
Comparison spectrum between Configuration 1 (PP-200 & EA-220) and Configuration 4 (PP-2000 & EA-2000)
As you can hear (here), each system has its own character. Configuration 4 (PP-2000 & EA-2000) offers greater openness and clarity, while Configurations 2 and 3 highlight the unique characteristics of each transformer. Ultimately, the preferred sound signature comes down to personal taste.
To experience the rendering of the different configurations for yourself, you can listen to the samples of each setup in DXD format and find the measurements here.
I hope this approach has allowed you to compare these high-end configurations, which one rarely has the opportunity to listen to.
Enjoy listening,
Jean-François
- An AMG Giro MKII G9 turntable
- A Phasemation PP-200 cartridge
- A Phasemation EA-220 RIAA phono stage, used in three distinct setups:
- Configuration 1: phono stage MC input
- Configuration 2: phono stage MM input combined with a Phasemation T-320 step-up transformer
- Configuration 3: phono stage MM input combined with a Phasemation T-550 step-up transformer
- A CSPort Analog Turntable TAT1
- A Phasemation PP-2000 cartridge
- A Phasemation EA-2000 RIAA phono stage, composed of six separate elements (Configuration 4):
- EA-2000T: MC step-up transformer specially optimized from the T-2000 model
- EA-2000EQ: newly designed vacuum tube LCR equalizer, featuring custom-made coils and other high-grade audio components
- EA-2000PS: power supply derived from the EA-1000, providing cleaner, more robust power with enhanced noise suppression
- DarTZeel Int LHC-208 Mk2 integrated amplifier
- Stenheim Alumine Five SE loudspeakers
Enjoy listening,
Jean-François
