audiofilet
- Joined
- Sep 9, 2021
- Messages
- 79
- Likes
- 38
- Thread Starter
- #21
I decided against the A50s because of all the information you and the others have provided and instead chose a used JDS Labs EL Amp for around 120 Euros.If you like the DT990's get the DT990 Edition in 32 ohm and you won't have issues driving it with the A50S.
or buy an amp instead that has higher gain. That'll work too and is cheaper than another headphone.
Only headphones with 2.5mm TRRS or 4.4mm Pentaconn, or XLR-4pin can be used balanced.
One can convert a 6.3mm SE to the 4.4mm Pentaconn but that won't be balanced, it will be using the SE option of the 4.4mm Pentaconn.
Now I have about 200 Euros left for a pair of headphones and I'm looking for used ones.
Is there anything that can beat the DT 990's Treble, low end and sound stage for 200?
Kinda getting to the conclusion that there's nothing else lol
