Experiencing a power cycle audible pop sound on Genelec speakers
HarmonicTHD
It doesn’t pop when powering the computer off because the interface has its own power supply maybe
I think is an issue with the way Focusrite handles the usb connection to PC as I read others have experienced the same
My solo pops when powering off windows but the 18i8 does not and more than likely is because the 18i8 has a power supply
Both pop when the interface makes usb connection with computer
This tells is bad design from focusrite and the way they handle the usb connection
Well only you seem to have the problem.
Can you post a screenshot of the Focusrite control?
HarmonicTHD
Do you have a second gen or 3rd?
Is your speaker on before you power on computer? Otherwise doesn’t make sense lol
Is your speaker on before you power off computer?
My issue may be the computer maybe the usb motherboard or the way it handles usb
When you turn on your pc, does the usb green light on interface turn on, then off and then eventually stays on?
Or when you power pc, the green usb light turns on and stays on?
Please read my post above. It is all there. Again, speakers on, guitar on, interface speaker and headphone volume and gain up. Now PC on. No pop whatsoever.
Then while everything is on. PC off. Again no pop.
Pancreas
Pancreas
Others have the same issue not just me. Focusrite control probably has nothing to do with it.
With solo there is literally no settings on focusrite control lol except basic stuff is all default
At this point im going buy a motu and check if it does the same, if it does then is my computer
HarmonicTHD
Or when you power pc, the green usb light turns on and stays on?Yes 3rd gen.
Yes 3rd gen
Pancreas
Pancreas
Does the green usb light on the interface
When you power on Pc, does it stop shining, then shine, stop shining, then shine?
Ill make a video when i get home
When i turn on my Pc the green usb light shine, then pop happens, then goes dark, then right before entering windows login, it shines again and another pop, then it stays on
The pops happen when light shines as the pc turns on this tells me is an issue with the usb
If yours doesn’t do this then the issue is my pc
HarmonicTHD
Yes the light comes on. And not any noise or pop during the entire powerup sequence. None, not even the faintest.
Please make a screenshot from Focusrite Control. I have a theory but might be wrong.
JustJones
I assume you've tried different USB ports, different cables, turned off sounds in Windows? You could try uninstalling all USB host controllers then reboot the computer.
Pancreas
Pancreas
Ok ill do that later im not at home but my question was
Does it light up, goes dark, light up and stays on when you start pc
Or does it simply light up once and stays on the whole time?
Blumlein 88
I've now tried my Antelope Audio Zen Tour. It is quiet under all circumstances. No turn on/off pops. Not start/stop clicks. No extraneous issues over monitor out or phones. Maybe this would be the one for the OP to get. It is discontinued. They have other Zen devices which may or may not be quiet. Find one 2nd hand, and you should be set.
It has an external wall wart supply. Can be connected via thunderbolt or USB. For this test I used USB.
@Pancreas
HarmonicTHD
I didn’t pay attention to the light. But I would assume so as it ran through the entire start up sequence. I can check again the light tomorrow (CET here).
Yuhasz01
The pop i refer to is the one that happens when you turn on Pc and the Scarlett connects to the PC usb
The pop matches the usb green light when it happens and it pops twice as the computer powers usb then cuts power the powers again all in a few seconds until window login screen appears. This interface has a power brick so is not because is trying to get power from the pc
This is bad design from focusrite and they probably use some cheap capacitor rather than something better interfaces use
My popping issue has nothing to do with playing guitar
Maybe the issue is my pc is an HP
I tried with a laptop same thing happens but the laptop is also HP so i dont know
This tells me is the interface why?
Cause it happens with headphones too
Even if i disconnect the speakers from interface it happens with headphones so is not the speakers
Is either the interface or pc or both
Not a Genelec speaker problem at all then.
JayGilb
West-Central Wisconsin
What model is your pc ? The led on/off/on maybe due to windows power saving settings as the OS loads after pc bios boot.
Pancreas
Pancreas
Hp pavillion 690-0024
2017 computer
I disabled all power saving options on bios tho and also updated the bios before and after
The pop happened before and after bios update
Before and after disabling all power saving on bios
I know my way around computer i tried many things
Im gon try reset the pc
Thing is i tried it on my brothers HP laptop and it did the same so i dont know
It could be an HP thing
MaxwellsEq
It would help everyone @Pancreas if you didn't start a new thread about the same subject every few hours. I've explained in two other threads that you turn power amps on last and off first. Lots of other people have told you something similar. By keep starting a new thread you are drawing different people in to give you the same advice that you've already received 5 times in 5 different threads.
Pancreas
Pancreas
And you think I don’t know this sequence? Bruh lol
I research stuff like crazy. I googled and read every forum, reddit etc posts about speaker pops
The reality is there are some interfaces and dacs that will block these pops it is possible and i want this i want convenience and i dont want to be in pop city
NiagaraPete
But you still haven’t corrected the thread title. It’s very unfair to the brand.
AdamG
Debunking the “Infomercial” hawkers & fabricators
Moderator
Reality
He can’t now. He has a 24hr egg timer and his posts/thread titles lock. As a Donor like you are, you get an unlimited edit perk. It’s a secret so don’t tell anyone else! ;)
MaxwellsEq
Then why don't to follow it, rather than trying to find an unnecessary fix?
