Experience with separate super-tweeters?
In an entire hobby made of toys, these are certainly one.
Historically, many speakers have hit the market with rear firing tweeters.
Back in the day, a big selling point for Merlin speakers was their rear firing tweeter.
Snell, Von Schweickert, Magico, Vandersteen, even those cray cray pricey MBL stacked Radialstrahlers toss an "ambience tweeter" up top.
You can stick one on the back of a speaker, or on top facing toward the back, or even up top firing straight ahead or up to the ceiling and simply see what your opinion is!
They can very very very! (!) room dependent.
Dirt cheap on Amazon for those "bullet titanium" babies, but for under 30 bucks you can toss then her or there and get a sense. They seem to add "information" for really narrow dispersion tweeters. Sometimes, these new fangled ribbon tweeters can seem to disappear when you stand up, so they sweeten the ambiance or the room for you.
No universal claim here, just playing with another toy and acquiring "empirical experience." No theory implied. :cool:
I'm unclear where one sets the cross over to their tweeter that tops out at 20k say.
I do the XO for super-tweeter in upstream DSP-EKIO plus one tuning high-pass (low-cut) capacitor; you can modify these depending on your prefered XO Fq.
My PC-DSP-based multichannel multi-SP-Driver multi-amplifier stereo audio setup with super-tweeters FOSTEX T925A would be of your reference, I assume.
Please refer to (and read through it very carefully) my this post #774 for the latest total system setup. Here, I copy-paste just one diagram, the total signal path;
To be honest super tweeter's seem rather irrelevant these days when any competent speaker can go higher than most can here, just another complexity and expense in my opinion. If the very top end isn't of high enough output, I'd rather look for something with more in that sense rather than have to buy a separate tweeter.
BTW, we, myself and @617, recently had very interesting discussion on the thread entitled “Are Super tweeters worth it?”; you would please carefully read our posts #43 through #61 on that thread.
That discussion guided me into a new series of audio experiments on reflective wide-3D dispersion of super-tweeter sound using random-surface hard-heavy material. If you would be interested, please visit my post here and posts thereafter.
I am going to try a pair of Aperions soon. In case you wonder if there is anything happening in the audible range, here´s a short demo.
By the way frequency range on paper means nothing without frequency response. If your speakers sound rather laid back and / or confined the super tweeter might add a sparkle at the top end.
Thanx.
I managed to order a pair of Dayton Audio AMT2-4 ribbon tweeters.
£160 for the pair, my hypocrisy only goes so far.
When they arrive, I am going to just hook them up through a plastic 4.7uF, feeding from the existing tweeter, just to see what happens.
It may sound absolutely crap (eBay!) or may show some promise. If anything, I will report back.
How did it it go, did it turn out well? Anyway what do you think of the tweeters? I´m considering these or monacor rbt-95 as an uppgrade in bookshelf speakers or as a freestanding add on.
Don't.
They are crap.
Thanks :) . Hard to find honest reviews.
I want to get more clarity (without harshness) in the treble range, and also tweek the upper midrange a little bit. I tested using these in the picture, the cabinets are ca 8x25x3 cm, in parallel with yamaha bookshelf speakers. But no matter how i connect them the midrange are way to loud and the ribbons are almost inaudible. If that is how they sounded in the their original setup then the ribbons were just for show. My crude guess is the philips ribbons used seperatly are not totally crap from what i can gather, so maybe there is a way to use them. My experiments will continue:)
You'll probably have to extricate them from their own crossovers and cobble up appropriate ones for your application. My guess (and it is no more and no less!) would be that they are may be padded down extensively to match the woofers' sensitivity.
Less constructively :( -- but my further guess, based on experience with other Philips drivers of similar Gestalt, is that they're some sort of planar drivers and not true ribbons... but, again, just spitballing, as some would say. :cool: :facepalm:
Yes, additional tweeters are enjoyable.
ESS AMT
Hivi RT2C-A attached to Lii P10​
Please say more, if you would.
Perhaps I couldn't get them to sing right.
Tried a simple capacitor & then added an inductor too, nothing made a difference.
What came out was a distorted buzz, if I recall accurately. The tweeters on my speakers seem to roll off pretty quickly past 7 kHz (to my ears, no measurements), but they were a clear reproduction. The AMTs did add abit more extension, but it was not a clean sound.
I gave up eventually. it was some time ago.
Still have them, boxed up for resale!
ESS AMT
Took the philip cabinet apart, tried to separate the tweeter but did not dare to pull it out so could not see the front. The backside of the membrane unit is flat plastic, quite thick. I´m not sure what these tweeters are, probably planar, Most likely been part of a surround system. The "midrange" look like an old simple radio speaker.
Found this: https://audiokarma.org/forums/threads/philips-mcd-702-708-908-and-fake-ribbon-tweeters.933159/.
Maybe not so much to work with then. Will try to test the tweeter separately by dislodging a cable to the midrange speaker, or using a cap.
The plan is to have a small cabinet with a tweeter (maybe also a midrange) that can be easily placed and directed. If i build my own DIY satellite tweeter cabinet i think I´ll use a nice looking a wood bowl/small box from a gift shop. From what i understand i can use a potentiometer between the main speaker and satellite for tweeking satellite volume(?). Having this type of separate units seems to me the optimal setup but I do not find many on the market, for 2.1 systems. at least.
Since the AMT tweeter has been brought up in the thread.
The columns below. Long DIY AMT line-source speakers. Built by a knowledgeable DIYer with plenty of time on his hands, who managed to buy a huge number of neodymium magnets cheaply and also had access to various machines (for plasma-cutting pole pieces, among other things). Among the best speakers I’ve ever heard. :)
(large listening room, a number of large bass boxes, and fairly extensive EQ may also have played a role in the positive impression I got from listening)
I don’t think there is anything like them on the commercial market.
I heard them when I visited this fair:
The picture you posted is a planar unit (90% sure).
PS. Are these ribbon speakers, or something similar to planar?
This one is AMT.
Again 90% sure.
View attachment 559927View attachment 559928
Is that Solhagas creations?
And if one wants more sparkle in their treble or whatever one could instead of adding more tweeters just dial up the top end with an EQ. The best thing with going that route is that you won't get that inevitable phase issues in the crossover while still get that extra treble. It's cheaper as well (because everone has a DSP in their system right?).
