Tom C
Hello,
The question:
Does anybody know how to run audio out of a web browser in exclusive mode, or know of some other work around for getting sample rates to change automatically to match a stream's native sample rate and bit depth?
The use setting:
I have a few outdated PC's and tablets around that I would like to use for audio only. Most of them won't run the latest OS's from Apple or Microsoft, and the one that does really strugles, as it is slow, laggy and a pain to use.
I'm subscribed to Qobuz, which I like for its sound quality, and also its versatility. That is, it can run on most any hardware platform, particularly if you use the web player. Then you just need whatever browser will run on the platform you're using at the time, which uses minimum system resources, and is usually not a problem if it is not the very latest version. But here's the rub: the web browsers I've tried (Safari, Edge and Firefox) all put out audio in shared mode, and I can't get them to use exclusive mode. That means the sample rates won't change automatically on the fly to match whatever is being played at the time. The sample rate can be manually selected in the OS sound controller, but you have to manually change it in the controller each time you select a stream with a different sample rate. It's especially a pain when using a playlist containing a wide variety of sample rates.
I know I can make life easy by just setting the shared mode to 44.1/16 or whatever, but I'm hoping not to compromise, since I'm paying for the service, the broadband connection, and capable output hardware. And it alows me to save by repurposing a computer deprecated only by software fiat that would otherwise become landfill.
The question:
The use setting:
