When I gave up buying vinyl in the 90s, the rule of thumb was that the standard LP had a dynamic range of around 45 to 50dB on a brand new major label recording. Some were better and some were worse.
The only exception to this when it came to popular music was Mobile Fidelity. Their releases would give you about 10 dB less noise and distortion. Also, usually they would last longer because the discs were so thick, but this was not always the case.
I only owned a few of MFs albums, but I was very crestfallen when my copy of Sergeant Pepper’s by The Beatles got a huge pop on one of the tracks after only a dozen playings. For me, that was the turning point where I decided that I would never buy vinyl again unless it was for a recording that was not available on CD.
This all being said, I’ve been hearing all of this PR crap about the Vinyl Renaissance. Is the product being made today any better than what was offered 30 years ago?
Has anyone actually tested what the sound to noise ratio and distortions are being produced by modern vinyl and the systems used to play them back (other than photo preamps)?
One of my hobbies is not only designing loudspeakers, but also audio engineering since I’m also a musician.
One of the reasons that I moved to digital audio from R2R tape is that digital offered greater fidelity and much less noise & distortion. Also, tape requires a lot more maintenance… And, oh, there was the fact that tape was/is really expensive.
So, you guys measure stuff here. Any thoughts about taking a modern vinyl recording and comparing it through software to its digital release? Give them a serious, objective measurement based comparison to show the difference between them.
I’d think that acoustic music would yield the best results and it would be optimal if the source was recorded digitally and released in a hi-res, 24 bit format.
I imagine someone will have done this in the past, but I’ve not seen it.
My experience makes me think that Vinyl will lose to Digital worse than the Chiefs lost to the Eagles at the Superbowl (BOOM!) this year. (Go EAGLES… yeah, I said it)
Sorry, got carried away.
Anyway, a delicate, hi-res mastered, acoustic music recording compared using the best of both formats. Run them through the best competitor software and see what the results are. Then, release the proof to the world.
You can even give Vinyl a mulligan by running the digital signal through a DAC and capture it with the input ADC.
Your thoughts?
