Evidence-based Speaker Designs
andreasmaaan
I got that part and I have wav file on my NAS. :)
How do I do IM measurement with it?
Ah, I misunderstood.
Play the WAV file from your NAS and then use the RTA window in REW to observe the output as picked up by your mic.
I'm not sure if REW can calculate the IMD automatically or if you need to do it yourself.
ctrl
.de, DE, DEU
Isn't pretty much all of that cooked into my EQ for LP?
No, the distortion of your speaker could be less than measured at 4m distance if your room and its objects cause additional distortion.
The distortion of your speaker could be significantly higher than measured at a distance of 4m, if in the worst case the phase shifts caused by the reflections increase the fundamental tone on average and e.g. reduce the third harmonic distortions by cancellation.
andreasmaaan
But aren't my drivers also radiating into half-space as rear-space radiation is funneled into TL tubes? I mean, you cannot simply absorb rear side radiation - you have to channel it somewhere.
The rear radiation of the drivers is out of phase from the front radiation. The TL tubes delay this output so that a useful portion of it comes out in-phase.
But none of this changes the fact that the baffle is of a finite size and that this size is small relative to the largest wavelengths the speaker reproduces.
QMuse
Don't you worry, I'm old enough to know how a floppy disc looked. :p
I don't think it knows how to calculate it, harmonics distortion looks ok but THD number is meaningless.
QMuse
Wouldn't the same thing happen with pink noise which I use when measuring response at LP, in which case I wouldn't get flat FR?
QMuse
True, but that doesn't change the fact that drivers are radiating only in half space. As soon as you attempt to take rear radiation away you will change the phase, and you have to let it somehwere out. How would a "true" infinite baffle design look like?
Isn't that true for every speaker design? You can't really make infinite baffle, can you? :D
andreasmaaan
They are not radiating only into half-space. At wavelengths that are large relative to the dimensions of the baffle, they are radiating into full space.
Obviously, in practice impossible. But,for all practical purposes, built into/onto the wall ;)
QMuse
Wall would also reflect some LF so even in that scenario they will not be radiating half space. :p
According to your definiton of infinite baffle such speaker doesn't exist. :D
andreasmaaan
Ofc not. Infinity is after all rather large ;)
But in practice any speaker in which the baffle is large relative to the wavelengths the speaker reproduces / the room it's in (ie when the baffle is a whole wall) is classed as infinite baffle.
QMuse
As such speakers are very rare no wonder Wiki sticks to their definition of infinite baffle. :)
andreasmaaan
Hmm, the definition implied in the article on TL speakers is not really the standard definition, nor is it necessarily the definition used elsewhere on Wikipedia.
I think it would be fairer to see that an ideal TL enclosure behaves like an IB in some respects.
Thomas savage
The Watchman
uk, taunton
So minimise driver distortion used crossovers to navigate frequency errors and think about the enclosure and how that interact with the room. People spend loads of money on room treatments but a speaker enclosure is in your room and it's big.
Think about the sound coming out the back of ya speaker, think about how pure the off-axis sound is as that's where the limits of drivers are and what separates true sound from reproduced sound.
more important than any other design preference, a speaker has to be played in a room that people live in, or if it's design dependent and there's no other way tell people what they have to do to their room in order to achieve the best performance.
Did I miss anything?
QMuse
Wow! Have you been teacher's liebling in school, sitting in the first row? :D
Thomas savage
The Watchman
uk, taunton
No I've had 4 cans of DIPA, a bottle of wine and half a bottle of vodka.
It's not a big issue you have to make something predictable ie a speaker interact with environment , a room , so you have to make compromises and that might ultimately lead to a less perfect speaker but applyed to a non perfect room dynamic = better performance these are design trade-offs.
That's what the Harman research was all about not the ultimate speaker in isolation but the mean average what works best in people's rooms.
Please correct me if I'm wrong.
QMuse
I think you're right.
P.S. What is DIPA?
