Early Reflections Are Not Beneficial
by
@Ethan Winer
This article is meant mainly as a rebuttal to those who believe that early reflections enhance sound quality in a typical home-sized listening room. By "home-sized" I mean a room less than about 20 feet wide, where reflections from nearby surfaces arrive soon after the direct sound from the loudspeakers. I assume most readers already know about
early reflections and
reflection points, but if not, this
RFZ Article on the RealTraps web site explains in detail. One proponent
in favor of early reflections is loudspeaker expert Dr. Floyd Toole, whose 2008 book "Sound Reproduction" has been deservedly well received. I'll address Dr. Toole's position later on.
http://ethanwiner.com/early_reflections.htm
I like Ethan's work, but there are a number of things I disagree with in this article. Here are just a couple of them:
But when played back in a small untreated room, the strong early reflections from nearby surfaces drown out the larger sounding reverb in the recording. This makes the music sound smaller and narrower, not larger and wider. As proof, headphones are fully anechoic having no reflections, yet music generally sounds larger on headphones than through loudspeakers.
Firstly, the research is quite clear that reflections need to be very early and very loud indeed to "drown out" direct sound, or even to shift/spread the perceived image.
Secondly, I am not someone who finds that music (other than potentially binaural recordings) sounds anything close to larger on headphones, so I just find that comment utterly strange.
One common myth is that rooms used mainly for playing stereo music should be treated differently, and less, than home theater rooms. But a big part of most movie sound tracks is music! Whether listening to music alone or as part of a movie, everything should come through clearly, with a flat frequency response and low distortion, and without strong early reflections clouding the sound.
It's not about movies vs music, but about stereo reproduction vs multichannel reproduction. In the latter case, the cues for spaciousness and envelopment are present in the recordings themselves. In the former case, they may need to be helped by the room.
However, I do agree with his general view that the smaller the room, the more likely it will be a good idea to absorb first reflections.
Why is it wrong to like a BBC-dip or low- even-order harmonic distortion and other types of "euphonic" seasoning but not side-wall reflections?
"Wrong"?
Firstly, all I've argued on this point is that (1) the evidence is stronger that most listeners
don't prefer it and (2) it's a decision often best left to the engineer on a recording by recording basis.
Secondly, I am not arguing that the presence of strong sidewall reflections is more
accurate to the source than otherwise.
I'm simply arguing (1) that most listeners prefer them because they tend to enhance envelopment, perceived spaciousness, and in some cases also apparent source width, and (2) that only in extreme cases do they significantly/negatively affect localisation (≈ imaging).
Moreover, we all prefer there to be some reflections present in our listening rooms. If you call my preferred reflections "euphonic" then you must call any reflections at all "euphonic" too, right?
And if you're against euphony of any kind, you must then be against reflections (and so on and so on
